Question about Brother MFC 7420 All-In-One Laser Printer
Brother mfc 7420 software won't install
Every time I try to install software, I get to the point where it say's connect to computer and turn on printer. I do that and nothing ever happens. That screen just sits there like that for hours until I shut off.
  • Brother Master
  • 1,684 Answers
First unplug the printer from the computer. Go into the device manager, under system in the control panel. You should see some devices listed as unknown device or it may have the printer name with a yellow exclamation mark by the name. Delete any of these that you see. Leave the printer unplugged and restart the computer. When it boots up reinstall the printer software and don't connect the printer until the software says to. It should go right through the install now.
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Feb 10, 2012
SOURCE: Refill toner Brother MFC 7420
open front cover, press OPTION button, on the LCD will appear a message "NEW DRUM?" ....DO NOT RESPOND....just type on the keyboard "*00" and there will appear a message "Accepted" and use it in your pleasure.
PS. in any case i blocked with paper labels the viewing windows from transparent plastic on the toner itself....
Mr. Brother, do not try to be smarter than your customer
Posted on Jul 17, 2008
SOURCE: I can't find the back door sensor on Brother MFC-7420
I have the answer. I just fixed mine. The sensor is not really on the door. You have to remove the door by openning it all the way and carefully sliding it out ( one of the pegs holding the door is hourglass shaped. This will slide out first. The other is round. You will see a black flap that covers a red drum. Pull the flap down carefully. There will be a six inch long rod it's about 1/8 of an inch in diameter. It extends from the middle of the flap all the way to the right side. This probably popped out of place. Make sure that it is all the way to the right as this is where the sensor is. There is a little spring on the bar on the left side. This should be straight up and down. if it is not, then you need to fiddle with the bar.
The trick was that the sensor is NOT on the door, but on this inner flap. When the door closes it pushes this flap agains the drum and the little bar activates the sensor.
Please do not applaud so loud, you are ambarrazing me!!! hehehe. Good luck!.
Posted on Aug 11, 2008
  • 320 Answers
SOURCE: error 2001 on brother mfc 7420
please tell me more! i just checked my brother manual and i do not see a error code 2001????????????
Posted on Feb 16, 2009
leroyal
  • 2120 Answers
SOURCE: mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Posted on Mar 10, 2009
the kowalski
  • 86 Answers
SOURCE: Black lines in copies and fax's Brother MFC 7420
If the black lines comes when using the ADF (top feeder), try to see if you get the same problem when using the scanner glass or receiving faxes. If you don't, you simply have to clean the glass strip to the left of the a4 sized scanner glass. Wipe it with a dry cloth piece, no paper and no water/alcohol. If you see some dirt there that you're unable to simply wipe off, try to use a cotton wool to "rub" it off.
Posted on Jun 14, 2009
My brother mfc-7420 will print but won't let me scan and i can not find my disk
Go to the Brother web site and put in your MFC info and you may download it for free. If you find it to be difficult you may call Brother for support and they will walk you through it. Do not have to be under warranty. Hope this help you out.
Aug 28, 2012 | Brother MFC 7420 All-In-One Laser Printer
How do we connect Windows 7 HP to Brother MFC-7420?
you can 1. connect it directly to your computer and let your computer recognize it. or 2 use the install Cd and install it on your computer.
May 15, 2011 | Brother MFC 7420 All-In-One Laser Printer
I want to install free driver of my brother MFC 7420 printer from internet but i can not geting correct site to download please help me
Hi There!!!
You can download the drivers & software here on this website
hope this helps!
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc7420_all
**On a Windows environment, to check your operating system you have to click on START>right click on MY COMPUTER/COMPUTER and click on properties
Hope this helps!
May 01, 2011 | Brother MFC 7420 All-In-One Laser Printer
I cannot use my brother MFC 7420, printer, fax, scan, copier on my window 7 software. please help me how to download the free driver or software.
You can download drivers from:
Select your version of windows 7 (32 / 64 bit). If you are unsure you can find this by right clicking on your computer in the start menu and choosing properties.
Please leave feedback if this was helpful.
Mar 18, 2011 | Brother MFC 7420 All-In-One Laser Printer
My Brother MFC-7420 test prints fine but says it's not connected to my computer when I try to scan. Help.
You need the brother scan software running on your computer before you try to scan unless you use one like picasso and initiate the scan from your computer.
Oct 29, 2009 | Brother MFC 7420 All-In-One Laser Printer
Need to download installation software for Brother MFC-7420 printer.
You can download the printer driver from the Brother WEB site.
Make sure you download the driver for your model printer and the Windows version that is installed on your computer.
Use this link to the Brother WEB site :-
www.brother.com/html/download/index.htm
Sep 27, 2009 | Brother MFC-7420 Printer
Scanner - MFC 7420
Get the manual, and you may need the install disk too. Look carefully at the usb port on the copier so you get the correct usb cord.
Mar 31, 2009 | Brother MFC 7420 All-In-One Laser Printer
Problem with Brother software.
You need to get the uninstaller from Brother and then re-install most upto date software downloded from Brothers Website. I too had trouble with the software
Jul 14, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
67 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
