Question about GE Refrigerators
Compressor not running or cooling - GE Refrigerators
  • lonc Feb 10, 2012
    how to check if compressor is good
  • GE Master
  • 5,370 Answers
It can be the problem with compressor itself or problem with start up capacitor beside compressor.
Click this link below for more details:---
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
This should help.Thanks.Helpmech.
Posted on Feb 10, 2012
Why is GE Profile Bottom Freezer Refrigerator not cooling
Check manual for proper setting.
Check compressor running condition. (set to lowest temperature and let the doors open. the compressor must run contineously. Feel if it is cooling up. If so then close the doors and observe the compressor running behavior. It should run for minutes before the compressor stops.
If compressor is running but no cooling effect it is either leakage of freon or loose compression. let it be checked by a certified technician.
If compressor is not running at normal temperature check your thermostat and OLP (over load protection) relay. Both must be closed circuit.
Aug 13, 2014 | GE Refrigerators
Wont cool compressor runs
If there is a small amount of cooling, you have a failure in the defrost system. If there is no cooling whatsoever and the compressor is running, check for a failed condenser fan motor or blocked or dirty condenser coil. If those items are all okay, you have a failed compressor.
Jul 26, 2014 | GE Refrigerators
1996 amana top freezer refrigerator not cooling
Check power to and from thermostat and to compressor relay. If compressor powered but not running, compressor fault. If compressor running but no heat in condenser, short of gas. If compressor running and heat only in first rungs of condenser, compressor poor pumper and needs replacing.
Apr 28, 2014 | Refrigerators
Does not cool either side fan runs and compressor seems to run
2 possible issues. If compressor running, but not cooling - No freon in the system, or compressor valves are bad, not compressing freon. Ideal would be to check pressures on the system while its running. Could be some kind of restriction. most common problem i would guess low freon level. Here are 2 of my videos i have on my channel. first is leak found at evaporator coils. i used leak dye to find it, second video is replacing compressor, but had compressor completely down. installed 3-n-1 hard start kit, but compressor did not come on, so replaced compressor with filter drier. Hope this will give you an idea what to do next.
Aug 19, 2011 | Maytag MZD2766GES Side by Side...
Haier Mini spilt HSU18VC7 compressor runs for 5 minutes then stop 3 minutes then run another 5 minutes and so on.
This is called short cycling. It sounds like the compressor is getting hot and opening a bi-metal overload, which shuts the compressor off. The compressor cools, because it is not running and the bi-metal contacts close allowing the compressor to start again. This will repeat itself and is usually due to low refrigerant, which usually means there is a leak in the normally sealed refrigerant lines. The refrigerant cools the compressor windings and if it is low it cannot do that, hence the shutting off of teh compressor, cooling down process and restarting of your compressor. Short cycling will ultimately ruin the compressor.
If this has helped you please give me a rating worthy of my diagnosis.
Aug 03, 2011 | Haier Heating & Cooling
My house have a gas heating and electric cooling system. When I turned the cooling on the outside fun started but the cooling system inside house does nto start. I tried heating system it dose not start...
if the fan outside is running then feel the compressor outside or listen to it if you can notice that the compressor is running the same time the outside fan is running also.
it could be that the compressor is not running.
but if you can notice that the compressor is making a different sound as it turn on, then the compressor is running but not cooling, then you could have a leak problem. there is no or little refrigerant in the system.
if you have a leak, please contact your local repair man to do it.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Heating & Cooling
Kenmore refrigerator not cooling or freezing
my refrigerator suddenly stop cooling all the fans run normal. It makes a click Noyce.
Jan 11, 2008 | Refrigerators
Amana side by side compressor not running
Cleaning the fins is always good. Is the fan by the compressor running? It needs to help cool the compressor. The description you mention sounds like the compressor is overheated and tripping the thermal overload on the compressor. See if you can turn if off for a day to let it all return to room temp then see if the compressor kicks on. If it was overheated it should run again for a while before overheating again. Let us know how that works and we can go from there.
Nov 29, 2006 | Amana ASD2326HE Side by Side Refrigerator
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
