Question about Minolta magicolor 3300 Laser Printer
Minolta Magicolor 3300 Imaging unit
The display shows imaging unit missing. The imaging unit has been replaced with a new item but the display still shows imaging unit missing.
  • jay7149 Nov 14, 2008
    installe new imaging unit and now the printer shows error message "imaging unit missing"
I had the same problem. Check out page 3-308 of this document.
Take off the side cover and re-engage the gear. Should solve the problem.
ftp://ftp.qms.com/pub/cta/out_going/other/diagcd/mc3300sm.pdf
Posted on Apr 17, 2009
    New Friend:
Mon photocopie minolta dialta di251 en defaut .il y a message "the imaging unit need to be changed
Posted on Nov 09, 2013
Message states i unit low/ just replaced black i unit, which unit is it requesting
Will tell you CMYK
cyan yellow magenta and black or the toner is low for the black
Mar 16, 2014 | Konica Minolta magicolor 4750EN Laser...
Reset imaging unit of Minolta MagiColor 2210
when you replace the image unit for what ever color is the machine asking for
Feb 11, 2014 | Konica Minolta Minolta MagiColor 2210...
Magicolor 3300 printing light
Check the image unit/drum print out the demo page find which color is printing light and replace that color image unit NOT the TONER
Mar 01, 2013 | Minolta magicolor 3300 Laser Printer
How do you calibrate a Konica Minolta Magicolor 3300 printer?
More then likely the Cyan Image unit needs to be replaced
Oct 25, 2012 | Minolta Magicolor 3300 Color Printer
Magicolor 3300 - Imaging Unit Missing
reseat the missing image unit or get a new one, or the sensor is bad for that image unit
Sep 30, 2009 | Minolta magicolor 3100 Laser Printer
Imaging Unit Missing on Konica Minolta Magicolor 3300 after paper jam?
I had the same problem previously. I had a small piece of paper jam in the imaging unit
pulled it out and got the Imaging Unit Missing error. I could not solve the problem so I called it in under the extended warranty. Even the printer tech could not solve this issue. But, I look at this file, took off a the side cover moved the gear an viola! fixed..
Try page 3-308 of this PDF.
Apr 02, 2009 | Minolta magicolor 3300 Laser Printer
Imaging Unit Missing Error
Hi, I had the same problem. The following Cause and solution may help you fix your machine.
All refereces to left and right are facing the front of the machine as if for normal use.
The cause is due to the connector on thtop left rear of the imaging unit. this connector is mated with a coresponding, retractable connector in the body of the machine. When you open the cover over the top of the imaging unit, this connector retracts back into the body of the machine and when you close the lid it should re-engage with the imaging unit, The problem is that it dosen;t reconnect. I have asumed that it is due wear in the connector operating mechanism. This solution was effective for my printer.
Switch Off!!!
remove the topcover (after removing the colour catridges )and. remove the left hand side panel. You will see a nylon gear mechanism. Sqeeze together the nylon clip inthe centre of the gear wheel, and pull the gear about halfway off. This should allow you to move the vertical geared bar up 1 notch. .Push the gear wheel back on and try the machine to see if it works ok. All covers will need to be closed and if it works ok , reassemle the machine. Job done -about 10 to 15 mins. It tookme alot longer to find it,so some feedback would be appreciated.
Paul
May 04, 2008 | Minolta magicolor 3100 Laser Printer
Missing Imaging Unit
When I had this problem the solution was a tiny piece of paper which was jammed in the machine.
When the jam was cleared the message went away.
Hope this helps
Jan 29, 2007 | Minolta magicolor 3100 Laser Printer
Minolta magicolor 3300 Laser Printer Logo
779 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
