Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Bypass thermal cut out - Dyson DC07 Bagless Upright Cyclonic Vacuum
  • Official Brand Answer
  • 2,572 Answers
Hi Pam,
If your machine seems to be overheating and cutting out during use, this is likely to be due to a blockage - the filter may also need a wash. The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
http://support.dyson.co.uk/support/dc07/dc07-standard/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
In normal use, the filter should be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for it to dry completely before replacing it.
This should resolve the issue, but if you're still concerned, please get in touch with us directly so we can provide some further advice. You can call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Posted on Feb 10, 2012
Can I safely bypass the thermo switch on my Panasonic vacuum cleaner? It has a chronic issue of shutting down after vacuuming about 200 square feet of carpet.
I would make sure the filters are clean for this vacuum. Dirty filters will cause a motor to overheat and trip the thermal switch. If this machine has bags make sure the bag is not full. On some machines there is a filter under the bag where it meets the motor housing. I would not recommend bypassing the thermal switch. It is there for your protection. The motor could possibly burn up without it.
Oct 12, 2014 | Vacuums
Hoover 5163 Fold Away
Cutting out the thermal protector is a way assuring a sale of a replacement motor in the near future.
Apr 04, 2014 | Hoover Vacuums
How do I tell what temperature my thermal fuse was set to blow at?
Hi John! You should contact one of BISSELL's Authorized Service Centers.
Here's a quink link to assist you locating one in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Feb 11, 2013 | Bissell 1425 Little Green ProHeat Handheld...
Riccar 100 thermal switch on vacum doesn't reset
If the button will not reset it is possible it has not tripped. They can go bad but it is very rare. You can remove the wires from it'll bypass it. If the vacuum runs after you bypass it then it should be replaced.
Feb 07, 2013 | Riccar Vacuums
Is there any known do-it-yourself fix for the nutone vx-550 overheating problem?
there is a way to do it, yes. However, are you sure that the PC board inside is not what is causing the problem?? I mean, are the lights on and function normally when you turn the switch on or off??
If so you can proceed to bypass the two thermal cut offs located on the field coil on both sides of your motor inside. Yes, it can be done without taking the motor apart.
Also, move the other thermal next to the motor and attach it to the housing near the back of the machine. DO NOT remove it unless you absolutely need to. IE test the unit and let it run for approx 20-25 mins. if it does not shut off there is no problem with the last thermal cut off. If it shuts down within 5 mins, take it out too. It could be faulty now.
Good luck,
Mark
Nov 11, 2010 | Broan-NuTone VX475 Bagged Central System...
Table saw not turning on
yes that is a thermal fuse. wait a couple of minutes and reset it. If the blade is dull, replace it.
May 02, 2009 | Vacuums
Possible reset on Thermal Cut-Off
This is not really expert advise but I have a vaccuum with hepa filters and if the filters get dirty My vaccuum acts like your what you are describing.
Jan 07, 2009 | Eureka Vacuums
Thermal senser
If it is going bad, it will cause the motor to shut down, replace it then you will know if that is the problem or a problem with the motor itself.
Mar 24, 2008 | Vacuums
DC07 cutting out
I sounds that your thermal fuse is cutting out. By no means try to bypass this thermal fuse. It protects your product from catching on fire. Replace the thermal fuse at a service center. How old is this product?
Okay,
Spurs21
Feb 13, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
74 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
