Question about Uniden Bearcat Pro PC78XL 40-Channels Base CB Radio
Install D104 mic to uniden PC78LTW
Astatic D-104
5 Suggested Answers
SOURCE: Matching Antenna, or ??????
Sounds like you need to go to a cb shop and have the ant matched up to the radio
Posted on May 29, 2007
  • 37 Answers
SOURCE: uniden pc78ltw
The pc78 is the same chassis as the cobra 29 so any info you san find on the cobra 29 will work the same for your pc78..What kind of problem are you having?? Chia
Posted on Jan 10, 2008
  • 773 Answers
SOURCE: how to adjust the dead key in a uniden pc78ltw
You change the dead key with the addition of 2 components to the board. There is no dial or pot inside to turn to adjust the dead key.
What you want to do to the radio is called a swing mod. If you are trying to adjust your dead key, it sounds like you are trying to run a linear amplifier. If that is the case, you should probably set your dead key to around 2 watts. Most amplifiers are good with 2 watts. If this is so, then do this:
Go to radio shack and get a 1/2 watt 100 ohm resistor, and a 100uf 35 volt electrolytic capacitor.
Open the radio and look for JV117. It is a jumper. It is located in the back left of the radio in front of the final resistor in front of the heat sink.
Use a de-soldering wick to remove the solder from the trace side of the board. Remove the jumper.
In the jumpers place put the capacitor. Make sure the black tab is facing the back of the radio, towards the final. This is very important because there is a positive and negative to the capacitor. If you do it backwards you can blow your radio.
Solder in the capacitor, then take the resistor and on the side you soldered, solder the resistor bridging the 2 pins of the cap on the trace side of the board.
How this works:
The resistor determines the amount of dead key. the bigger the resistor, the smaller the dead key, the smaller the resistor, the higher the dead key. (dead key will only go as high as it was before you put in the mod.) A 100 ohm resistor gives you about a 2 watt dead key.
ALSO! you are going to want to find VR4. Its a little pot towards the back right center of the board. Then turn it all the way to the left. This turns up your modulation, and will make the radio swing to full PEP wattage, around 20 watts.
If you have a watt meter that reads avg wattage then you can gain more wattage by adjusting L14. It is just right of VJ117. it is a white or brown plastic tank with a copper coil around it with a slug in the center covered by a little way.
*do this only if you have a meter, also, do not transmit on your radio without an antenna connected or a dummy load or you will blow the final.*
Remove the wax and then while saying a steady ahhhhh sound, slowly back out the slug until you have peak wattage,(when the needle no longer increases.) You do not want to back the slug out any more then is needed for full wattage, other wise you over bias the final and lessen the life of it. So once the needle stops going up while giving a steady ahhhh into the mic, back it in a hair just to make sure its not over biased.
And as always, if you are not comfortable doing this your self, take it to a radio tech at a radio shop. They are usually found at truck stops.
Posted on Oct 16, 2009
Ironfist109
  • 3018 Answers
SOURCE: I have a uniden Grant
Wiring 1 4 pin D104 mic to a Uniden Grant CB is as follows -
  • Pin 1 - Shield - Shield
  • Pin 2 - Audio - White
  • Pin 3 - Transmit - Red
  • Pin 4 - Receive - Black
Regards, Tony
Posted on May 06, 2011
Mic wiring diagram for a realistic Navaho TRC -490
Check out this website www.qsl.net/g4wpw/astaticbook.pdf. It should help you out. Also, your D-104 should have the amplifier in the base. You'll see a hole in the base with an adjustment beneath it. You will have to adjust your transmit level with this. Make sure that you have a battery installed!
Dec 13, 2017 | Astatic Radio Communications
Astatic d104 wiring for Yaseu ham radio
( 9 Stand ) Astatic D104 to Yaesu FT 990
Pin 1 is White
Pin 2 is Red
Pin 7 is Shield/Blue combined
Aug 12, 2014 | Radio Communications
Want to use astatic d104 mic for motorola maxtrac two way radio not a cb radio
With using a D-104 on a Maxtrac, you will probably need an audio amplifier.
Tom
Feb 13, 2014 | Radio Communications
D-104 wiring to a cobra cb
Find your radio on this page and then look at the wiring diagrams
Oct 11, 2012 | Astatic D104 T - Ug8 Crystal Microphone...
How do i wire my d104 m6b mic for my president dwight d cb raido
This must be the right pinning
Pin 1 = shield / blue
Pin 2 = white
Pin 3 = red
Pin 4 = black
good luck,
Gerard
Feb 05, 2010 | Astatic 636L Noise Canceling Microphone...
I have an astatic 4 pin d104m6b amplified
Hello there
Nice mic i have 3 of these
here is infornation that you can use to get the diagram i like the first link a lot better though it is in full color Ok just look belowtis post and it will be there ok? I hope that this is very helpful for you
Best regards Michael
Repairing the D
These Astatic D-104 microphones are all vintage. ... Doing so will reveal the
simple wiring and the wiring diagram, pasted to the plate on the inside. ... http://www.k3hkr.com/D104_repair.html - 4k - Similar pages I am needing the wiring description for the astatic d104 - FixYa Oct 24, 2009 ... HELLO THERE The silver eagle d104 is wired just the same as the knight ...
astatic echomax 2000 unilli eagle wiring · wiring diagrams for ... http://www.fixya.com/support/t3271236-am_needing_wiring_desc... - 125k - Similar pages
Nov 17, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Looking to install astatic echo board in uniden PC78XL
usally on most radios you will unplug the wire that comes from the number two mic plug. you will hook you sheid witch is the 2 little black wires from the echo board to number one mic plug. then the two wires will go to wire you unplug and the other one will go to number 2 mic plug.
Jul 04, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
What is the output of an ASTATIC D 104. Regards Pal horvath
This may answer your questions:
Astatic D104
Although this is for a later model, it will surely have characteristics close to yours.
Nov 18, 2008 | Astatic Audio Players & Recorders
Uniden Bearcat Pro PC78XL 40-Channels Base CB Radio Logo
46 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
