Question about GE Microwave Ovens
The metal is showing inside. The white coating is pealing. Is this dangerous?
The peeling of the white coating inside of the microwave oven is dangerous in terms of creating a fire hazard and potentially contaminating the food you cook within it. This can be prevented by cleaning up all splatters and spills immediately before using the microwave oven again. You can fix the peeling by replacing the microwave oven or repairing it. To repair it, you will have to remove the peeling coating and then repaint the interior of the microwave with paint that is designed for microwaves in general. Though, if you do this, you will have to let the paint dry up for at least 24 hours. I hope this helps you!
Posted on Feb 10, 2012
Testimonial: "Thank you very much. Do you know what kind of paint or where do I get this type of paint? "
  • Victoria Feb 14, 2012
    You can buy this paint from any good hardware store like Home Depot. I believe the paint you can use is enamel paint, but just to be sure, ask customer service about this at Home Depot. They would know the answer to this best of all.
High temp paint is NOT the right stuff... Why you ask? Because after applying it, after 1 hour to NO MORE than 8 hours later, it must be heat cured in a NON-FOOD over @ 650 degrees F for 45-60 mins to cure it.
The best, longest lasting paint IMO is a good EPOXY base prime with an epoxy appliance paint. If rust holes are in it, it can be fixed, but MUST be done proper (welded) and sanded smooth as any sharp cabin disturbance will cause arcing. Preperation is key so STRIP all the factory cheap azz powdercoat and start from metal. Roughing is not enough as I can tell you the rust you see extends much farther under powdercoat that looks perfectly fine. I usually chem strip with Aircraft remover (Don't substitute). This will get the bulk, but not all of it unless you reapply 10x and the cost per can would defeat fixing it. A heat gun works wonders.... I start by using slow cure epoxy glue to seal the seams in the cabin. Let sit overnight. Hit the epoxy to smooth and rough it so the finish coats stick proper. With this technique the paint should outlast the factory cheap china clearcoat over bare steel by 4x or better.... In other words.... The last time it will need to be done (Except maybe in commercial apps)
Posted on Oct 20, 2012
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: plscti/ teflon coating inside the microwave
Is it plastic or paint? I would be surprised if it were plastic, as that would probably not withstand the microwave energy.
If it needs to be repainted, that can be done if it is cleaned and dried.
High temperature appliance paint is available from stores like Wal-Mart or Lowe's.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 04, 2008
caroldon
  • 17130 Answers
SOURCE: The clear coating inside the glass door is crumbling. Dangerous?
It depends on how much the radiation is dissipated. Normally the grill on the door prevents and escape of radiation and so this cannot be a threat but a reading outside the door will be good to confirm and if so the door must be replaced.
Posted on Nov 30, 2011
The white ceiling coat has come away and is falling off. Microwave is out of guarantee. Have I any come back on this. Also, is this dangerous?
Is this by chance a Samsung Microwave?? I just answered a similar question with a picture right before this. In the other post, it looked like the Micro was either painted while it was already rusted or it is rusting from the inside out into the cavity where you cook food. In either case, regardless of age, I would contact the manufacturer and explain to them that this could be a factory defect. Safety issue would be possible paint/rust flakes in uncovered food. If manufacturer puts you off, contact Better Business Bureau.
Mar 30, 2015 | Microwave Ovens
Is my microwave safe to use if the inside of the oven is pealing?
Most likely if the metal screen in the door is intact. That screen and the metal cover on the back and sides surrounds the insides of the oven reflect the microwaves back into the oven. Just be careful about the peeling plastic inside.
Jan 26, 2015 | Microwave Ovens
Arcing and flashing during cooking cycle
Arcing and flashing either has to do with having metal parts inside that are not chromed perfectly (better yet only put metal in if it's a microwave convection oven on convection setting only), or some of the powder coating on the inside of the cabinet is damaged. Or a twist tie etc was inside during use. If the cabinet is damaged dispose of unit.
Oct 20, 2013 | GE Adora Over the Range Microwave....
Nov 29, 2011 | Daewoo WM1010CC Microwave Oven
Coating inside oven has de-laminated and rust is forming under coating. Warranty?
Hello spark... no warranty unless the microwave is under 1 year. If there is a lot of rust and delamination you are best off to replace this oven.
The problem with delamination is that it exposes bare metal and can result in dangerous arcing.
If it is not real bad, sand off the rust and spray paint it with microwave cavity spray paint available at this link http://www.appliancezone.com/ShowProduct.aspx?ID=8338&AspxAutoDetectCookieSupport=1
Joe
Thanks for choosing Fixya!
Feb 20, 2011 | GE Microwave Ovens
Inside my Daewoo KOR-6Q27 microwave oven, underneath rotating glass plate, white layer (or paint) have piled off and rust have started to emerge. Can this problem be fixed or i have to buy a new one? Was...
I have painted many Microwave oven cavities. You have to sand down the pealed off rusted areas and completely clean and degrease. Before painting, I use laquer thinner as a cleaner degreaser. Fumes can be a bit strong but it has worked well of me. I normally buy an automotive spray paint. They have a lot of different colors and a lot of the import colors can really come close to the color inside the microwave. Spray on thin layers till you get good coverage and make sure you let it dry thoroughly before trying to use. The paint in a Microwave isi not a special microwave energy protective paint. it is only there to make it look pretty and protect the metal. So a good automotive paint normally works fine.
Sep 25, 2017 | Daewoo Microwave Ovens
I'm getting a flash inside the oven and the plastic on the inside roof has a burn mark. I removed the plastic cover over the micro wave generator and it did not spark. is the oven dying? It is a 1983 0ver...
It looks like the metal part inside the oven is exposed to the high frequency rf waves. this may sound strange but try coating the metal part with fresh paint. remember no metal inside the oven will stand the waves created inside the oven the spark u see is the waves hitting the exposed metal part inside the oven
Oct 13, 2009 | Magic Chef MCD1311ST Microwave Oven
Paint off inside top of microwave exposing metal. Safe to use?
It would be dangerous to do so. Any exposed metal inside a microwave is source for sparks and is extremely hazardous. I would recommend getting the paint job done up, or even better, buy a newer model.
Nov 15, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
PEELING COATING IN MY SUNBEAM MICROWAVE OVEN
Yes, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, you can have rust and arcing.
Aug 10, 2008 | Sunbeam Microwave Ovens
Plscti/ teflon coating inside the microwave
Dec 09, 2007 | Daewoo KOC-925T Microwave Oven
Microwave Ovens Logo
740 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
