Question about HP Mini 1000 Netbook
HP mini 1000.....MAJOR battery/power problem
Not long ago, my netbook decided (on its own) that it would only run on while plugged in. The battery will take and hold a charge. The control panel even indicates the charge when it is running. However, you unplug the cord and the computer immediately turns off. It doesn't go through the shutdown process...it just turns off like you flipped the switch. I have no clue how to fix this and am desperate to get this thing fixed as I need it to work on my dissertation. PLEASE help if you can. I don't think replacing the battery will fix anything since it does recognize it and charges it appropriately. I am, however, replacing the power cord because if you turn it a certain way, it will let the computer turn off. My 18 month old pulled
  • Skippy Feb 10, 2012
    the cord hard enough to bend the plug that goes into the computer. I wonder if the plug-in on the computer itself needs to be replaced due to him pulling on it and it not allowing for the immediate connection to the battery when it isn't plugged into the power source. I am thinking it has lost a connection internally.
Bowmans IT
  • 85 Answers
SOURCE: Compaq Presario V2000 touchpad/battery charging problems
I noticed you were talking about over heating issues. Does the mouse issue happen when the computer is on for a period time?
I know with some laptops there is software for the "gadgets" on the mouse pad. If you have software related to it.. try reinstalling.
I am getting mixed thoughts of what you maybe talking about... please explain.
Posted on Nov 13, 2007
SOURCE: HP zv6000 battery problem
I am having the same problem when the power cord is plugged directly to the computer - power light flashes - once battery is dead so is the computer. I have a docking station that plugs into the big port on the right side - that still works and does charge the battery. The thing that sucks is once the battery dies - I am back to the docking station. At least you could use the computer as a "Desktop" before shelling out a grand for another laptop! You can pick up a docking station pretty cheap.
Posted on Jun 19, 2008
Benzschwagel
  • 33 Answers
SOURCE: HP Pavilion dv4000 battery won't charge
all you really need to do to find out if it might be broken is to check and see if that DC Jack on the computer is "wiggling" around, if the center part is moving around. If it is, then there is a chance that it is broken. I used to work at a computer store where the owner would resolder new DC power Jacks into laptops, but he was the only one in town who did that. So you might want to check around at the local computer repair or electronics stores to see if someone does that type of thing. Also, have the power supply checked out, it could just be dead.
Posted on Mar 25, 2009
  • 10406 Answers
SOURCE: HP6720s run slow when plugged in??
Start -> Control Panel -> Power Options
Ensure that when plugged-in, it is set to "Maximum Performance".
Posted on Apr 27, 2009
  • 425 Answers
SOURCE: What is main power supply for a laptop?
I would say that is most likley the motherboard not the power supply and this is a pretty big job you would have to take the laptop apart if the laptop is under warrenty I would use it otherwise you would most likley be better off getting another computer unless you are very good at taking computers apart. You can go to HP website support and get repair manual and it will tell you how to take apart.
Posted on Dec 07, 2009
Mini 110 will not work. died suddenly
Eichh, Darn!
Check to see if there is any rattling or anything that is loose on the netbook, Check the cell Battery, Remove the Battery and plug in the charger and see if it does anything. I've had a problem in the past with my Hp Laptop-Its a real pain.
Hope this helps ;) Zkhan
Apr 20, 2011 | HP Mini 1000 Netbook
My hp mini just shut off on me and i cannot get it back on
The first thing that I try with a situation like this is:
1) Remove power cable from unit.
2) Remove battery from the bottom of the unit.
3) Attempt to power the unit on without any power going to it (unplugged.. no battery..it won't turn on obviously.. but that's what we want.)
4) Plug power cable back into it and test. If it works, reinsert the battery and thats it!
Mar 30, 2011 | HP Mini 1000 Netbook
My mini keep going into hyperination
Click Start>Control Panel>(in the drop down select icons) Power> In power select a power option such as balanced or edit the one you currently have. You can set your netbook to never go into hibernation. There are different settings for plugged in and battery power.
Mar 09, 2011 | HP Mini 1000 Netbook
My netbook is frozen i cant turn the power off at all
Remove the battery and pull the plug from the wall. Hold the power button down until it turns off. John
Jan 22, 2011 | HP Mini 1000 Netbook
Cannot power my netbook. Trouble getting a charge now cannot charge at all.
take out your battery and try plugging in just the netbook and see if it turns on then. If it does not it could be a problem with your power adapter. If it does turn on then your battery is probably bad.
Jul 08, 2010 | HP Mini 1000 Netbook
Low wireless signal strength compared to other computers - the netbook consistently reports about half the wireless signal strength that a Dell laptop sitting next to it does. in low signal strength areas...
For HP Mini 1000, the wireless device can be problematic.
I will recommend the HP Mini 210-1084. This has the fastest wireless in the HP Mini range of Netbooks.
Good luck.
Jul 17, 2010 | HP Mini 1000 Netbook
HP mini wont turn on and power led blinking
Removed the battery - power it up from your a/c adapter then refit the battery -
Jun 26, 2010 | HP Computers & Internet
Sincerely, Previously introduced: Name: Albert T...
There is a coin cell battery inside the netbook that needs to be changed.
Mar 29, 2017 | HP Mini 1000 Netbook
How can i remove the password in the HP MINI 1000 netbook while i did not even know my password it just came out asking a CURRENT PASSWORD? How can i reset the BIOS of HP Mini 1000?
remove cmoc battery from motherboard for a minute then connect it again password will remove
otherwise change bios chip is the only solution
Jul 16, 2009 | HP Mini 1000 Netbook
Hp mini 1000 - no startup display
you got error this windows/OS system so u need to re-install the OS/Windows..good luck and have nice day
Jun 18, 2009 | HP Mini 1000 Netbook
HP Mini 1000 Netbook Logo
73 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
