Linksys WRT300N Wireless Router Logo
Posted on Feb 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Linksys nat problems
Anonymous
Level 3:
  • Master 550 Answers
  • Posted on Feb 11, 2012
Anonymous
Master
Level 3:
Answers
550
Questions
Helped
420169
Points
1147
You will need to change some settings on the Linksys router.
See How to change NAT type to open
Watch video:
1helpful
Haveing problems with moderate nat type need help changing it to open
Open up the Browser interface to your Linksys (http://192.168.1.1/ if you left it as default), and go to your Security section. On the Filter tab, check the box beside "Filter NAT Redirect" and "Save" at the bottom.
If you have an Xbox and you keep the settings as automatic in the network area, you should have an open NAT.
How to change a NAT to open?
Here is a direct link to ehow this will tell you step by step on how to change the NAT settings hope it works good luck
http://www.ehow.com/how_6017590_do-change-linksys-nat-settings_.html
How do i change my nat type on linksys wcg200 router device page?
The NAT type on this wcg200 cannot be change. Its either you turn off the nat, Which will disable the routing feature of it.
If you having a hard time connecting to an online game or having problem with a certain application ,l would advice you to just perform port forwarding on this router.
In doing port forwarding you need to get the ports that is needed to open for that certain application to work.
I hope i answer your questions
Cheers,
KJ
1helpful
2answers
Restricted nat for xbox / linksys 160n router need to open
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here
to know more about router and network
1helpful
OPENING NAT FROM STRICT TO OPEN
Sory to say this .....1 find a tech who knows networking... or.. call Linkys support to help with reset/setup...My final solution.... buy a different router... I've had trouble With Linksys before.
NAT
First, you need to get into the user interface for the router.  To do that, just open your web browser, type in 198.168.1.1 & hit enter.  A login prompt will pop up if you're able to access the router.
If you've never done this before, the username is blank & the password is admin
What, exactly do you want to do with the NAT firewall?
To enable/disable NAT: click on setup, then click on advanced routing.
To filter Internet NAT redirection: click on security, then click on filters.
You can find this information in the User guide provided by LinkSys at:
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1166859876500&displaypage=download
Select your version number, then click on User Guide when it comes up.  User guides & Interfaces for the BEFSR41 are almost identical on every version.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
