Question about John Deere Garden
2210 excessive motor shaking
Replaced motor mounts still having excessive vibration can push down on muffler and it goes away
  • dannatho Feb 10, 2012
    this is a john deere diesel motor[yanmar] any help needed
SOURCE: 2003 Nissan Altima
Check your exhaust system, some bolts used to loose or gone on Altima 02-06. Especially check the bolt close to the joint between exhaust manifold and front pipe. Check if your sway bar rubbing your exhaust pipe.
Posted on Oct 17, 2008
  • 205 Answers
SOURCE: Excessive vibration of the steering column
Sound more like out of balance tires, or bent wheel. Unless this vibration is even in park. Then I would say something is up against a part of the steering that shouldn't be.. Or your exhaust system is bent or touching part of the undercarriage that it shouldn't be. Was the car ever wrecked?
Posted on Mar 28, 2009
  • 260 Answers
SOURCE: I need to replace motor mounts 2000 mazda 626
they might need to be tightened thats all.
Posted on Apr 10, 2009
  • 31 Answers
SOURCE: car has excessive all-over vibration - especially when fan motor engaged
Does the car stall on hard stops or turns? when it is in park does it shake less than when it is in gear.. If it shakes more while driving, it may be the tensioner, which is the bracket that is with the belt next to the alternator. sometime when driving it may squeak, then stop completly. If it just shakes, then it is your motor mounts. try tightning them and see if they are corroded. you may need to replace them
Posted on May 20, 2009
SOURCE: I get excessive vibration in my 06 Street Glide fairing at idle.
I have a 2007 street glid eand have been through 2 sets of fairing brackets. it started with around 500 miles on the bike. very bad design, I had the factory bracket reinforced and problem solved. My old mans bike, same problem. Check the fairing brackets,
Posted on Jan 17, 2010
I have a 2004 gmc envoy with a 4.2 motor....it has a slight vibration while at idle but my main concern is why my entire motor and vehicle shakes violenty when i shut the vehicle off.
I think what you might have is called dieseling on shut off. Newer engines run much hotter than older vehicles and require a fuel shut off solenoid close to the engine. If this solenoid goes bad, on vehicle shut off, excess fuel is still being fed to the engine. Even though there is no spark because the key is off, the engine is hot enough to ignite the fuel causing the shake and shudder. I'm not 100% sure of this but thats what it sounds like. If the solenoid is working properly and shuts off the fuel line like it should there is no excessive fuel to ignite. Thus no shake or shudder.
Apr 10, 2015 | GMC Cars & Trucks
2004 Ford Focus vibrates/makes noise.
I have an 04 zts and mine used to make a lot of noises like you have and I had a bad motor mount on passenger side.Replaced it and no more rattles like that
Dec 26, 2012 | 2004 Ford Focus
I have an unusual shutter or vibration when accelerating.
Motor mount or CVC joints.
CVC joints can be ckecked by trying to see if there is any ratteling or excessive movement in the whole housing while trying to shake it vigorously.
Motor mounts need to be inspected for cracks or tears in the rubber areas of the mounting.
Also look for loose exhaust system parts by trying to shake the exhaust.
Please rate my answer,Gary
Sep 25, 2011 | 1995 Subaru Legacy
My car runs really bad when it is wet or raining and it said the 5th cylider is miss firing. I replaced it and now it runs worse. The steering wheel shakes when it is idling
the steering wheel shaking at an idle is a whole seperate thing. if it shakes while idling i would say its a bad motor mount (or mounts)
If the rubber breaks or wears out in the center of the mount that the engine bracket bolts to, then the center of it lays closer to the metal outer shell of the mount from the weight of the engine. The outer shell is bolted directly to the frame so it resonates vibration through the frame and body instead of 'floating' in the center of a rubber cushion.
Once your accelerating the engine rotates up in the mount lifting the center off of the shell so the vibration goes away.
Jan 06, 2011 | 2000 Mercury Sable
Cbr 125r 05 vibration
Your camchain maybe worn resulting in chain slap when engine loaded when still cold, or some valve lap delay resulting in pinging or blowback. (coughing). A top end inspection may be required
This may effect the vibrations but is likely to be loose engine to frame mounts or loose steering head.
Check play of rear shock mounts top and bottom for any play. This would impact through the frame and tank, bars etc., but is more to do with road surface and speed.
Are the wheels balanced?
Thoroughly inspect ALL bolts (engine mounts, engine head bolts, pegs, handlebars, triple clamps, swingarm, exhaust header and muffler mounts) for tightness as vibrations are one or two steps away from tumbling down the tarmac. Vibrations are the main cause of bolts loosening......
Goodluck and Cheers.
May 12, 2010 | Motorcycles
My 2003 neon vibrates heavily even at idle more so when i gas. the guy i bought from said he just replaced the motor mounts?
Check the mounts are secured correctly.
When engine is cool to touch try gtrabbing it and shaking it while looking at each mount to check for excessive movement
Apr 14, 2010 | 2003 Dodge Neon
Vibration through the car Transmission-motor Linkage?
Check to make sure both headlights are tight,,,when it rattles at idle go feel the headlight and hold it and see if the noise and vibration goes away,sometimes the headlight has too much clearance and causes a massive vibration,,if thats not it try...loosening all the motor mounts and rock the car back and forth and them retighten them,it reseetles the mounts and sometimes fixes the issue,,also check the lower engine and trans mounts for wear.
Oct 30, 2009 | Saturn SW2 Cars & Trucks
Why does the engine shake when idle 1998 caravan
maybe because your rpm's are too low to the point that seems like its going to shut off causing vibration or possibly motor mounts may need replacing that can also cause excessive vibration
Jun 08, 2009 | 1998 Dodge Caravan
Car has excessive all-over vibration - especially when fan motor engaged
May 20, 2009 | 2002 Kia Rio
Garden Logo
57 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
