Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Battery Stopper broke off
Well, i dropped my camera today and when i got home i opened the battery compartment to charge the batteries, and the stopper came flying out. How can i fix it?
  • 374 Answers
You need to send it into Casio's repair center to have that fixed. I don't believe they will just send you that part. Call the repairs center at 800-706-2534 and then keep choosing option 1. Tell them what's going on and that you would like to send it in for repairs. If they ask just lie and tell them you already talked to tech support. LOL
Posted on Jul 08, 2007
I dropped my Nikon D60 and now it does not power on I would like to know why???
There are several possible reasons. One is indeed the battery. If the camera powers on with a different battery pack then that would point rather conclusively at the battery.
Another possibility is that the drop damaged or broke the battery contacts inside the camera. Another is that the drop damaged or broke something else inside the camera.
First, try another battery pack. If you don't have one, go to a Nikon dealer and ask to try one. If the camera powers on with that, then buy a new battery and dispose of the old one. If the camera doesn't power on, then you'll have to have the camera serviced.
Dec 16, 2011 | Nikon D60 Digital Camera
My digicam won't start
There could be a couple of reasons why your camera would not start.
Before considering it to be defective, verify that the camera has batteries inside and that these batteries are charged. To do this:
  1. Locate and open the battery compartment.
  2. Identify the type of batteries needed and purchase new ones OR
  3. Recharge the batteries with the recharger provided.
  4. Place the new/charged batteries inside, closing the battery compartment.
  5. Try to turn on the camera.
If the camera still doesn't work after verifying that the batteries are in order, remove the memory card and any other accessories that the camera may have and try turning it on again.
If still the camera won't turn on, one last step can be performed if and only if your camera uses standard batteries (AA or AAA). If this step is performed incorrectly, you could short circuit the batteries, which would discharge them. This procedure will not damage the camera if performed correctly. Please pay attention and do exactly as explained:
  2. Remove the batteries.
  3. Place the batteries back inside in the opposite direction than the one indicated. If the position indicated is for the positive end first, place the battery with the negative end first. Do this process for all the batteries.
  4. Close the battery compartment.
  5. Attempt to turn on the camera. It will not turn on, but this step is necessary nonetheless.
  6. Open the battery compartment.
  7. Remove the batteries.
  8. Place the batteries in the correct position according to the indication.
  9. Close the battery compartment.
  10. Attempt to turn on the camera.
If the camera still does not work, it is likely that it is defective. At this point you should take the camera to an authorized service center.
Mar 30, 2011 | Cameras
Haven't used my Canon rebel xt for awhile but tried today and it will not turn on. Purchased new CR2016 battery and fully charged the other battery. Has not been dropped or misused. Please help
Aposta,
It is possible if you haven't used the camera for a while that the contacts inside the battery compartment need to be cleaned. This can be done with a q-tip and some alcohol.
Thank you.
Mar 21, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Easyshare M1093 is wont stay open
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Dec 19, 2009 | Cameras
Samsung S1050 -out of focus - beeps twice and switches off
The drop indicates that you have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Samsung S1050 Digital Camera
Camera won't power up
You might try cleaning the battery compartment of the camera to make sure that the contacts are not corroded.
Jan 07, 2009 | Canon PowerShot SD600 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
I dropped my Lumix and the little lever in a battery compartment got broke.
maybe you can do by yourself but its wise let technician to do it more knoledgeable to do it.
Nov 24, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
After one frame battery icon flashes ( battery is full charged)
The problem is with the electric contacts between the battery and the camera. You can try cleaning them with a clean pencil eraser. Make sure you don't leave any eraser debris in the battery compartment. It is best to do this while holding the camera so that the battery compartment door is "down" so that any eraser debris will fall out of the door onto the table rather than fall into the compartment.
Oct 13, 2007 | Canon EOS-1D Mark II Digital Camera
Camera was dropped and is not on
Take batteries out and have them checked, and make sure they are fully charged. Take a pencil eraser and clean/polish the contacts at base of the battery compartment Take a look at the battery-comp cover place and make sure the contact plate is firm replace batteries switch on OK No? Open the battery compartment, place a piece of foil across the batteries and shut it - turn on -OK No? Press the cover in OK No? Them it has broken beyond your reach and needs repair or replacement
May 22, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
52 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Steven Wander
Steven Wander
Damen Wong
Damen Wong
Are you a Casio Camera Expert? Answer questions, earn points and help others
