Question about Exercise & Fitness
We have a NORDICTRACK C2050 TREADMILL (NTL1095) - when you start it will go for about a minute or two and then it just about stops but the power is still on and belt moves slightly
  • 9 Answers
SOURCE: Nordictrack treadmill C2100 belk is not slipping
Several issues, drive belt that drives the walking belt could be loose but you should smell rubber if its slipping.
Something could be caught in the track causing extra drag, its easy to do if you have kids or pets
Check for when you last lubed the track and walking surface, with no silicone it will drag and bog at low speeds
Posted on Oct 22, 2009
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
  • 103 Answers
SOURCE: Nordictrack EXP 1000 Treadmill Quits after 10 Minutes
Hello There, Thank you for all the information. It appears as if your walk belt is worn. What is happening is the friction from the bottom of the belt is actually causing the motor to overheat (there is a thermal cutout inside where the 2 blue wires go) When the belt wears the cloth on the underside becomes flattened out causing too much surface area to contact the walk board, thus the extra friction.
To check your walk board you can loosen the adjusting bolts on the rear and while lifting the walk board look underneath. If there is any wear/white areas then you will need to replace the board as well. You will be able to tell by just rubbing your hand across it and check for any places where the black film may be coming off.
Also the only time you really need to replace any of the rollers is when the bearings go bad or the pulley on the front roller separates. The rollers are about a 1% chance of causing this problem.
Good Luck! and great question, Tim
Posted on Feb 21, 2010
  • 218 Answers
SOURCE: NordicTrack 2500 R Treadmill
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Posted on Aug 11, 2010
  • 218 Answers
SOURCE: my NordicTrack EXP2000i Will not
controller is bad
Posted on Aug 13, 2010
How do I fix a NordicTrack C2050 treadmill that has abruptly stopped?
see if you can remove the motor hood and look at the drive belt. it is a little belt from the motor to the front pulley to turn the walking belt. its either broke or fell off
Oct 21, 2014 | Nordic Track Nordictrack C2050 Treadmill...
Nordictrack c2050
see the video attached and fix it. God bless you
Dec 02, 2013 | NordicTrack Exercise & Fitness
I have a Nordic track C2050 treadmill one day everything was working great the next day the only the #1 and #7 speed button worked decline up and down stopped working plus all program buttons not work
replace the old batteries ( if your system has batteries, clean the spring contacts from oxide, corrosion, etc with contacts cleaners) put a new batteries.
2) tight and clean the ribbon cables from display board
3) tight and clean the uppers and lower connector very well.
4) adjust the REED switch, tight the connector, clean it, and test the reed for open or faulty. see the diagram attached.
Oct 25, 2013 | Nordic Track Nordictrack C2050 Treadmill...
C2050 belt does not turn
LUBE THE deck belt inmediattely, maybe you have WORN deck belt
2) LUBE the rollers bearing too
3) test the drive belt motor for worn, replace or adjust it
4) test the input voltage motor, if there are the motor need repair, See my personal TIPS.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 24, 2012 | Nordic Track Nordictrack C2050 Treadmill...
Knocking noise when the motor is running on the left side
meant the motor have being hit and u should fine a repair shop
Jun 26, 2012 | Nordic Track Nordictrack C2050 Treadmill...
How to activate my ifit
I will try to help you, the feature of software is the same. you can do it, activate your ifit. Nordic Track C2050 ACTIVATE IFIT -The Nordic Track C2050 is a treadmill that was targeted toward the budget-minded fitness enthusiast. It is a model of treadmill that is no longer being manufactured by the company. When it was still being manufactured, it developed a reputation for being an entry-level treadmill that featured a console that was easy to read because of its brightness. 1. Incline Change
o The Nordic Track C2050 allows users to change the incline of the treadmill with a simple touch of a button. This treadmill features both increase and decrease buttons for the incline. The incline of the machine will change by .5 percent every time the buttons are pressed. With each press on the incline buttons, the machine will take a moment to actually reach the incline setting that was just selected.
Capacity of Weight
o Users who are larger than or weigh more than the average person will be pleased with the added capacity of weight that the Nordic Track C2050 allows. Unlike most treadmills in its economy class that only allow a weight limit of 200 to 250 pounds, this model lets users who weigh as much as 300 pounds use the machine safely. Larger people can get the benefits of a cardiovascular workout on this treadmill without worrying about damaging it.
Heart Rate Measurement
o This Nordic Track model allows users to measure their heart rate. All the machine requires is for users to place their feet on its foot rails and grasp the metal contacts with their hands. The Nordic Track C2050 then works to determine your pulse, and the symbol of a heart will eventually show up in the display. After a couple of dashes show up, your heart rate will be displayed. Users who want to be certain of getting an accurate reading should ensure their hands are clean when gripping the metal contacts.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
Nordictrack C2050, belt was slipping and I got the cover off. and black stuff is all around the belt moving the roller that moves the treadmill. When I walk on it the belt would shuffle and sometimes the...
I am not an expert on what you may need to order but I do want to give you a link in case that may be helpful... FitnessRepairParts.com has parts lists for several versions of the C2050... look for a decal or label on the machine to get the exact model number, then click on that model and look in the list for 'Roller, Front' or 'Roller, Rear' or 'Treadbelt.' Hope that helps.
Also if you need someone to come look at it you can find a list of servicers near you here
Feb 17, 2011 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
80 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
