Question about Panasonic Health & Beauty
Es8249 My problem concerns the freestanding self-cleaning unit. I have everything connected properly including the power cord, Panasonic cleaning cartridge(brand new), and water tank (filled). However, when I put the shaver in there it does not give me the option to clean - only charge. Any ideas?
delgriffith
  • 97 Answers
SOURCE: Shaver will not charge or clean in the base
All you have to do is take the base apart. Turn it upside down, and there are two plastic clips on the rear portion of the base. Press them in with a key or screwdriver and wiggle the base a bit to remove the inner portion from the outer shell. Make sure you unplug the unit and remove the cleaning cartridge before doing this. Once it is apart, place a small wedge underneath the portion of the electric contact that sticks out to touch the shaver, and press the back of that portion out so that it slightly bends the contact strip and makes it stick out a little further. Then remove the wedge and put the base back together. It will work again, as the contacts can now protrude to touch the shaver and run the cleaning and charging cycle.
Posted on May 09, 2009
brector3
  • 1624 Answers
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
brector3
  • 1624 Answers
SOURCE: If I place my shaver in the base it does charge
It sounds like the pump is bad. If so, the whole cleaning ubit will need replaced. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-360-complete-clean-charge-base-p-116.html
Posted on Sep 07, 2010
Testimonial: "thanx, i tryed a few other ideas that others suggested but nothing helped, so at least im replacing something that couldnt be fixed"
Cytherian
  • 124 Answers
SOURCE: Clean and Renew stand for braun 8595 does not seem
The circuit board on the shaver may have become faulty. One thing you can try is to fully charge the shaver first, directly connected to the outlet, and then try using the cleaning base. Also, be sure that the fluid level is sufficient. Lastly, you may be able to buy a used but working condition cleaning station off of eBay. New replacements are a bit costly.
Posted on Nov 07, 2010
  • 12 Answers
SOURCE: why does my clean and renew station leak all over
I figured out the problem for my Clean & Renew unit. Mine is 2 years old. About 3 months ago, I cleaned the buildup of whisker material from the TOP of the drain port [Left Side as you look at the unit] If you take out the cleaning solution cartridge and turn the unit upside down, you see the pump and the return ports. The return port is the smaller of the two. I found that there was a mass of dried whiskers in a few clumps clogging the return port. These clumps must have come loose and got caught within the drain port. I had noticed when I had the leaking problem I could hear bubbling just after the pump ran and the shaver turned off. I removed the clumps of whiskers and no more bubbling sounds and NO MORE LEAKS. My guess is that the fluid was draining back into the intake area and leaking on top of the cartridge. Hope this helps.
Posted on Dec 11, 2010
All 5 spark igniters not clicking
Could be range of problems including:
Power not connected/turned off
Ignitor ports clogged
Incorrect operation
Manual is available via Google
Aug 09, 2015 | Frigidaire Gallery FGGF3032MF 30"...
F1 beeping
Hi Andrew! Sounds like the unit is having a runaway temperature concern. F1 or F10 indicates the temperature has become too high for the unit. A professional is required to check the sensor probe in the oven. If the oven is overheating, disconnect its power. If oven continues to overheat when the power is reapplied, a technician will need to replace the electronic oven control (EOC).
Sep 04, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire pleb30s9fcd oven overheating whats wrong
Hi there!
From what you have described it sounds like the unit's thermostat and or temperature sensor is not functioning properly. Typically this is not a DIY type of job to complete on your own. Please contact a professional that your manufacturer suggests. Please let me know if you have any other concerns or questions.
Mar 30, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have a frigidare brand self cleaning gas range and the oven will not light
If the rest of the unit work properly, then you are having an electronic ignition issue. Contact your manufacturer and then a professional they suggest to have it repaired.
Sep 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Why isnt anything digital working on my stove?
you need to check the main power terminal block and ensure there is proper power to the unit.if the power is correct at the terminal block then you will have to replace the main electronic control board
Oct 13, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My unit 3576 H was working properly. I purchased it about 16 months ago. I was watching TV and not using the hard drive or DVD when the power went out, then shortly came back on. It was connected to a...
Take the unit aparts,check the power fuse on the board,replaced the power fuse,that is near the a/c power cord.Replug it back like 48 hours later,the recoder should reset it self and work,if not ur right it a paperweight,not worth repairing.
Oct 02, 2010 | Philips DVDR3576H DVD Recorder
My self clean feature is on and there is a bad smell. Is this normal?
Yeah that is just the oven incinerating everything in it including the parts and wiring for the oven to operate properly...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Sep 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I was using the self cleaning device and the entire thing shut off and now nothing works. "Entire Appliance Does Not Operate"
Hello- Sorry- no good news here. 'Self clean', or self- destruct' as Techs call it, has burned out a circuit or switch somewhere on the unit. The best case is a burned wire connection. The worst case is control circuit failure.The solution involves on-site diagnostics by someone qualified to make sure repairs are needed and done right. Inspection should start at power cord and move to control board. Multiple failures can occur during 'self-clean', but sometimes only one part will fail. Find a good Tech to look it over and give you an estimate before repairs. Remember- Don't 'self-clean'!   It's costly and dangerous.    Please acknowledge this post if helpful.. Have more info if needed.  Thanks-- Ed
Mar 24, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Health & Beauty Logo
248 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
gautam jha
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
