Question about Singer Sewing Machines
The stop motion screw on my singer 20U has been jammed since I broke my needle trying to sew over a bump of fabric. How do I release it?
The machine still operates but I cannot open the screw to fill the bobbin without the needle being engaged.
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
  • 3 Answers
SOURCE: singer 7422
Make sure you have the machine threaded for the bobbin and not threaded through the sewing path. Also, check to make sure that the bobbin is pushed directly against the post as far as possible.
Posted on Apr 13, 2008
bargainbox
  • 1388 Answers
SOURCE: Sears Kenmore 1168280 (Old machine not used much)
Untangle any mess under and around the needleplate very gingerly trimming threads as you go if necessary....remove and clear.
Undo the needle clamp and remove the remains of the needle.
Open the door for the bobbin and bobbin case and undo the clips holding the hook in place......don't force anything, just ease any tangle loose slowly.
You may want to take a photo of how it goes back together if unfamiliar, or lay the bits out sensibly, so you can replace easily later.
Inside the bobbin/hook area is the most likely region for thread jamming the motion of everything, so make sure all is clear and clean, then.......
Without replacing the bobbin or hook, test the handwheel after cleaning before re-assembly.
You may also want to check the take-up crank for thread jams........the small arm in the top cover that moves up/down to "take-up" the top thread has a cam attached to the top shaft and often tangles thread around the shaft, open the L side cover to access.......remove thread by unwinding handwheel manually ....again be patient and careful not to break threads.
Best Wishes
bargainbox.com.au
Posted on Jun 08, 2008
SOURCE: bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Posted on Sep 29, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
My Singer Quantum 9910 is completely locked up.The wheel can't be turn.
take it in far a warranty service check
the needle breaking may have altered something or broke something inside
Jan 20, 2016 | Singer Quantum 9910 Computerized Sewing...
Sewing machine jammed with needle down and material can not be removed. Help I can break the needle, I really just want the fabric out.
loosen the needle clamp screw then you can pull the needle out with pliers not damaging any of the machine or bobbin area .
Oct 30, 2015 | Singer Sewing Machines
My machine used to free motion quilt without a hitch, now it is skipping stitches.
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever?..,/
May 23, 2015 | Bernina Virtuosa 150
Machine well not work with the quilting foot what can I do
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? h
May 17, 2015 | Juki Sewing Machines
What is thread setting for sawing fabric with
I don't think you'll get it to feed on a domestic sewing machine, the foam is going to be too thick and difficult to feed through. I've used an industrial Singer 20U to sew vinyl to 1/4" foam which has a dacron layer glued to it, ie like carpet underlay thickness. This was to make replacement seat covers for ride on mowers; the Singer was strong enough to sew through both layers in a straight stitch, I could manage to overedge it on my domestic Elna but need a roller foot to stop the vinyl from sticking to the foot, and a leather needle. Even then, it wasn't easy.
Oct 10, 2013 | Brother XL-2600
This is the 2nd time I have had to buy a new bobbin case base for my Bernette. I can't figure out what the heck I am doing wrong. It will jam and then after awhile it no longer wants to sit in...
That sounds like a horizontal bobbin case held in by a magnet like the Janomes have now: if so, then yes, I understand your frustration as I've replaced it on my Janome 1600P twice, always when I try to push the machine with sewing denim hems, it just won't hack it, the case will dislodge, then the needle strikes it and it jams up, again and again and again. However, my machine was serviced last year and the mechanic fitted a longer finger that holds the case down and it did fix the problem. So have you spoken to a Bernina dealer and voiced your dissatisfaction with it? Maybe they need to look at an after market fix too.
Otherwise, only other option is really to change the machine; I now use my trustly old Singer 20U when I need to seam heavy thicknesses as it can handle the heavier weight fabric okay.
Oct 21, 2011 | Bernina Bernette 75
Brand new machine. Heavy Duty Singer 4423 I sew ripstop tarps including a double layer of grosgrain edging. After one tarp the machine has begun to squeak horribly with each stitch. Why? What can I do as...
I would suggest that the words "heavy duty" applied to a machine sold for less than $150 is probably taking a little bit of artistic licence.
Grosgrain edging is very stiff so you will probably need at least a 100 size needle for this and they may well go blunt pretty quickly. This could be the squeaking noise, needles will "pop" and squeak if they are blunt. Change the needle and see if it stops.
I would suggest that if you are doing straight stitching in large volumes for commercial purposes, this is not the right machine, you need something like a Singer 20U industrial machine, a good workhorse which will do straight and zig zag stitches.
I have one of these with a 3/4 hp motor in a table and it is so strong, great for sewing tents, horse blankets etc. We used it for attaching vinyl to 1/2" foam for ride-on tractor seats, something it did really well. Different needle system to domestic machines and can sew heavier gauge thread too.
Sorry, this probably isn't what you wanted to hear about your new machine. Try changing the needle and see if it stops the squeaks. But you may need to reconsider your choice of machine.
Aug 30, 2011 | Singer 4423 Sewing Machine
Sewing Machines Logo
81 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
