Question about Moultrie MFH-DGS-100 Digital Camera
MFH-CDC When a fresh or old battery is replaced the DATE/TIME is displayed. From this point on you can't change the mode. It seems that if the battery meter doesn't reflect battery power then the camera doesn't work! I seem to have this problem when the weather turns colder. Have had this happen to other cameras as well.
    Problem Solver:
  • 6 Answers
Turn it off, remove the disk and turn it back on. I have several of these that do the same thing and this usally works. Once the battery meter lights up you should be able to insert the disk and switch it to auto. For some reason sometimes it doesn't like the disk inserted when it powers up.
Posted on Nov 30, 2008
    New Friend:
Where can I get an oweners manual for my MFH-CDC camera
Posted on Jul 31, 2013
Replaced battery on Timex Indiglo WR30, now it loses time. Second hand hangs uo when it reaches area between 11 and 12, then continues on seemingly ok
need to put in fresh battery I know you may have just bought new one but it is old check for date on back package
May 13, 2017 | Timex Watches
I changed the batteries in my stc-tgl2m, re-set my time/date info and everything seemed fine. When I came back the next day it hadn't taken any pictures and I noticed the time/date had not changed. I shut...
Look for corrosion on the terminals that the batteries connect to. Make sure these are shiny. It sounds like you are not getting the right voltage. With a camera that old the contacts may have gotten some battery acid on them at some point.
Nov 20, 2013 | Stealth Cam Wildview Game Camera -...
My forerunner 50 is randomly resetting itself. Sometimes it shows Lo Batt but then doesn't sometimes the screen goes blank but pressing any buttton a few times brings the display back at which point I have...
Remove the battery, clean the contacts with alcohol, and replace with fresh cr2032 battery. Instructions are here: http://gnjmch.com/public/tips/GarminF50.Battery.html
Mar 05, 2011 | Sport & Outdoor - Others
I-40 camera will not go to picture mode and start taking pictures
Have you done the time/date setup? Online manual says it goes auto after 4 minutes, but perhaps the date/time need to be setup first? Online manual here in case you lost your book :)
http://images.ebsco.com/pob/moultrie/catalog/dgs-i40-user-manual-compressed.pdf
be patient, it takes a bit to load
Aug 26, 2009 | Moultrie MFH-DGS-200 Digital Camera
Changed battery on roberts r871 radio .time date needs to be set
hold down mode button until display flashes, change time with up/down buttons. Press mode button once to change to date use up/down to move through dates, the time display will show year you are in the further you press the up button the further in the future you will scroll. This radio holds date & day information depending on the year displayed. Leave flashing to time out after adjusting.
Apr 27, 2009 | Emerson Audio Players & Recorders
Locked up
On my Moultrie MFG-DGW 2.1, I was unable to change settings etc... It seemed to be locked at the Date/Time screen. I powered off the unit, removed the memory card. Turned on the unit. Then I could change the settings. I made my changes, powered the unit off, reinserted the memory card, turned the unit back on and it read the card and I could make changes too. This happens from time to time. I just have to follow those steps to clear it.
Hope that helps.
Oct 28, 2008 | Moultrie MFH-DGS-100V2 Digital Camera
System Time/Date in BIOS setup not functional
reset your bios with jumper settings.
Apr 03, 2008 | Computers & Internet
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Date and time reset at power-on
Canon point and shoot cameras have an internal backup battery (a very small watch battery sized cell). Look under your battery door - do you see a small tab that has "CR1220" or something like that marked on it? If so - this is your backup cell. Just replace it and you will be good to go. If you do not see this, then the backup battery is buried deep inside the camera and would require full disassembly to replace. David Millier Advance Camera Repair
Feb 18, 2007 | Canon PowerShot A510 Digital Camera
Moultrie MFH-DGS-100 Digital Camera Logo
1,010 people viewed this question
Top Moultrie Cameras Experts
AZBen
AZBen
Steve
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
