Question about Echo Gas 20 In Blade Double Reciprocating Double Sided Hedge Trimmer SHC225
I have an echo HC150 sheer and when I start it up the blade does not move. The throttle goes up and down when I give gas but the blades wont move.
This is a HC150 Echo Hedge Trimmer. Starts up and runs, but blades do not move. I loosen the bolts on the bars but it still does not move.
  • 97 Answers
SOURCE: what would cause excess vibration in an Echo
Check for loose blade to case mounting bolts or cracked support bar.
Posted on Mar 19, 2009
cactus bob
  • 267 Answers
SOURCE: Looking for owners Manual for Echo HC 1500 Hedge
this is the same attachment as mantas tillers use to make there tiller motor into a hedge trimmer try there website for a download ................if this answer helped please rate 3 or 4 stars this will keep me in the paid answer department
Posted on Apr 02, 2009
  • 203 Answers
SOURCE: I need coil and spark plug gap settings for echo
0.026 inch, or 6-8 mm is the plug gap.
The ignition coil air gap range is 0.012 - .016"" or .3 - .4 mm. This is the gap between the flywheel and the ignition coil.
An easy way to gap your coil is use a normal business card between the coil and flywheel, tighten the screws and remove the card.
Posted on Oct 23, 2009
  • 110 Answers
SOURCE: echo manuals hard starting hedge trimmer 1500
all echo manuals are available on line at echo.com for free
Posted on Nov 01, 2009
dmiesner
SOURCE: ECHO HC-1500 hedge trimmer wont stay running cuts off
Replace the fuel cap.
Posted on May 29, 2010
Changed my TPS & IACV now truck wont start unless given gas
You should be able to look down the throttle body and see into the air bypass chamber that the IAC uses to divert air around the throttle blade. Look to see if the pintle is all the way out closing off the flow of air. When you turn the key on you should see the pintle move back and allow air to move through. If the pintle is not moving that it may be stuck in the bore. Especially if there is a lot of carbon build up in that passage.
Jan 22, 2016 | 1992 GMC Sierra
Have a echo 150 gas hedge trimmer motor runs blades don't move what could cause that
Inside the bottom panel, is where the grease etc is... you can take the cover off to make sure it's greased up inside, if it's running and the blades aren't moving when you throttle it, then they can be siezed , or the gear under the panel is off line or broke.
Aug 16, 2015 | Echo Garden
Why won't my 1984 Oldsmobile Delta 88 start?
if throttle blades dont move look on side of carb were kick down cable was replaced possible throttle and kick down popped off or damaged
May 14, 2014 | Oldsmobile Delta 88 Cars & Trucks
Changed blade on echo edger now the blade turns non stop without giving it gas
Back off the idle speed screw CCW until the blade stops turning, but the engine keeps running. Hope this helps!
Jun 11, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Auger blades won't turn
You need what they call a "friction wheel" replaced.
Oct 31, 2009 | Garden
Engines on but the blade won't move?
Do you perhaps ahve a vine, wire, rope or some other stringy thing between the head and shaft? Sounds as though that may be your problem. Look closley, they try to hide!...Lee
Aug 28, 2009 | Garden
Sticky throttle on 200 Chevy Astro
There was a recall on the throttle body blade on the 4.3 a few years back for the throttle body to stick in the close position. Yours being 9 years old makes me think that there not going to do anything for it but give you the solution to the sticky throttle blade.
The solution was to change the blade. You can try cleaning the throttle body blade by spraying throttle body cleaner in to the barrel of the throttle body. If you look down, you'll see the carbon build up and it may just need and good cleaning.
If that does not work, you can buy a new Throttle body blade which is only held on by two screws on the throttle blade shaft.
Start with cleaning the blade and throttle body with throttle body cleaner. Just follow the instruction and you'll be fine.
Keep me posted and good luck.
May 31, 2009 | 2000 Chevrolet Astro
Echo Gas 20 In Blade Double Reciprocating Double Sided Hedge Trimmer SHC225 Logo
296 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
