Question about LG Washing Machines
LG WM0642HW won't stop filling. Floods house
I came home tonight to find the kitchen flooded. The LG WM0642HW washer was sitting there with the door open, half the load washed out on the floor, no lights on, and the water running into the machine and out onto the floor. Any ideas what failed? I am suspecting the fill valve, but open to other ideas.
SOURCE: Duet whirlpool washer mysteriously floods the
I had the same problem, found it at about 2 am. No fun. Pretty easy fix. The part on the back of the washer where you screw in the water lines in needs replaced. Its been 2 years but I think it only took about 30 mins to fix once I had the part. Remove the top of the washer (couple screws in back) The part that the hoses screw into has a wire that goes to it that opens/closes the vaule when it needs water, its not closing all the way and water is continuing to fill. Good luck, think the part was about $50 or so. I would shut off the water at the wall in between washings until its fixed, and when on vacation. The hoses always have water in them if the. good luck
Posted on Nov 08, 2009
jsrock516
  • 5911 Answers
SOURCE: flooding! Help
This is usually a symptom of a pressure switch malfunction. The pressure switch is located in the operator console behind the load (or water) level knob. It is cylindrical in shape and has an electrical connection and an air hose attached to it. In many cases, the only problem is that the air hose has come loose and fallen off the fitting on the pressure switch. All you have to do is reattach it. HINT: placing a small zip tie around the air hose where it connects onto the pressure switch will create enough resistance to keep the hose from vibrating loose again. Just a snug fit will do. Over tightening can break the fitting on the pressure switch. You will need to open the console and inspect it. To open the console, it comes off in a few different ways depending on the year and model of the washer:
1. If you have removable end caps on the console, they simply pry off by lifting from the the back exposing a screw under either end. Remove the screws and the console lifts up.
2. If the end caps do not come off, place a putty knife in the front corner of either end of the console where it meets the washer top and push in while lifting up. This depresses a retaining clip and the console will lift up.
3. Some consoles have a screw located on either side in the back that you need to remove and it will then lift up.
Be careful when you lift the console. There are small plastic hinges holding it in place and they can break if you aren't careful. Place the console in its resting position by laying it over the back of the washer. The pressure switch will be easily accessible. Double check the hose like I previously stated and double check to make sure all the electrical connections are in place.
If you check the switch and find that everything is in place as it should be, you may have to replace the switch. Post back with your COMPLETE model number (located around the rim of the washer tub opening) and I can track down a part number for you.
I hope this helps.
Posted on Apr 11, 2008
  • 39 Answers
SOURCE: my maytag neptune sometimes fills with water and floods my floor
sjhtlh
It sounds like the water valve is starting to go. i would get a tech out just to make sure.
brent
Posted on Sep 29, 2008
larryyb
  • 291 Answers
SOURCE: MY WHIRLPOOL WASHER FLOODS YHE FLOOR ON FILLING BEFORE IT START T
you have a bad pressure switch or the hose come off in a unbalanced wash ,,, look in the top and check the hose (about a 1/4 clear hose) and make sure its still connected to the valve and if so replace the valve.
Larry
Posted on Nov 25, 2008
  • 100 Answers
SOURCE: water leak
there is a blockge so the water comes out the way it went in when spinning,
check the filter at the bottom of your drum.
rear of machine, take panel off and look in to see black rubber attached to drum about 3" diameter. filter in there.it's a kind of basket with a ball float in it.
put back the way it came off as only fits 1 way.
Posted on Feb 11, 2009
Maytag ice maker floods the kitchen when water does not shut off when filling the ice tray. What's the reason and fix?
What is the refrigerator model number? In most cases the dual water control valve with have a mechanical defect and cause the water to flow by the valve even when off. W10408179 Water Inlet Valve
If you can find your model number around the fresh food section door frame please post so I can insure I give you the correct part numbers, Thanks Sea Breeze
Dec 04, 2012 | GALAXY Microsystems 25.4 cu. ft....
Front-load washer fills with water when not in use.
Water valve is defective. Replace it before it floods your house.
Nov 16, 2017 | Washing Machines
The cold water will not stop running and floods the house
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Aug 12, 2011 | Maytag Centennial MVWC500V Washer
Our lg washer model wm0642hw tub clean cycle stops
software problem. regarding smell, after wash keep the door opened for ventilation, use fabric conditioner etc. also check whether any rodent has gone inside and messed up the place
Mar 18, 2010 | LG WM0642H Front Load
Water dispensor comes on by itself and floods kitchen
You need to replace the switch! You should do this before long to prevent it from flooding while you are asleep or away from the house. Please call us for parts! We will be happy to get this for you. Ella
Aug 25, 2009 | Maytag MSD2756G Side by Side Refrigerator
Washer is over flowng
Seems very likely that the water level sensor is malfunctioning, and not telling the water inlet solenoids to close when the appropriate water level is reached.
Mar 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water Overflow
hi there,
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
Oct 10, 2008 | Whirlpool LSR7333 Top Load Washer
Washer is filling up with to much water...
possible fill valve is sticking open when filling after starting washer disconnect power and listen to see if water is still running in if so replace fill valve.. if water stops possible water level switch or small hose to switch plugged ..drain washer remove screws on each side of door frame front will pull off...small hose on some models was attached to pump housing and would become plugged with lint ckd for restriction in hose from bottom to top remove screws in console to acess other end attached to pressure switch
Aug 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
229 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
