Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F1 code i have the whirl pool cabrio top washer , after two years, it now throws a F1 code every time you try to start the washer, it takes at least 5 times to restart it. i have called whirlpool twice and they are refusing to address the problem, cause my washer is too old.... so my question is, if we pay our own money to fix this, will it happen again, and is this common with whirl pool applainces? we are getting ready to re do our kitchen and we planning on purchasing whirl pool
    President:
  • Whirlpool Master
  • 2,651 Answers
Well they refuse to adress your issue under a warr. beacause of age , but im certain that a whirlpool auth. servicer will glady adress your issue. As for the F1 generally relates to a faulety control board. but would want( a serveicer ) to check in more detail before jsut askin you to replace the board
Posted on Oct 24, 2008
Calibrating whirl pool washer after repair
Linda. I know nothing about this washer, but I did get this info from the attached link, you may still have to call a tech.
Put into diagnostics (left, right, right, right, left, right) @ done you see errors, @ spin you run calibration(this will clear codes and reset board). good luck
http://forum.appliancepartspros.com/washer-repair/537059-whirlpool-cabrio-washer-not-completing-spin-cycle.html
Apr 18, 2016 | Whirlpool WTW5700XW 3.6 cu. ft. Cabrio Top...
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
I have a top load whirlpool cabrio washer. Every time I start a load of laundry the F1 sensor comes on. I have to restart the wash 6-10 time before in finnally works. Why?
Hello
Error code F1 is caused when the control on your washer is either bad or about to go bad. This is a common issue with Whirlpool Cabrio washers and they are aware of this. I have also seen them replacing the control without any charge, don't really know about the labor charges but they usually won't charge you for the part. Please get back to me if you have any other questions.
Kevin
Nov 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error f1 flashes after just a few seconds of turning on the wash cycle. if i turn off power and try to start again it will somtimes start if not i turn off and try again sometimes it takes 3 or 4 times to...
The Whirlpool Cabrio and Kenmore Oasis (same machine) are infamous for this problem. Depending on the serial number you may be entitled to a new control board installed for free under a recall program. Call Whirlpool for eligibility. I had just had mine replaced last week for free and it runs fine now.
Apr 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Get FI error everytime I use the washer Happens 4 or 5 times before it evers starts the cycle then happens at least once during the wash cycle
Get in touch with whirlpool and they should fix it for free. F1 is a control board error, and whirlpool did a recall on the cabrio control boards, so they should take care of it for you.
Dec 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My top load 4.5 cubic whirl pool cabrio washer does not seem to clean my clothes. it almost acts like there is not enough water
your agitating belt might be slipping or worn, try holding the switch down with a pencil, and keeping the lid open and see if the agitator is moving or sluggish..good luck.
Jul 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code on cabrio washer
CALL 18002531301 AND TELL THEM YOU HAVE THE F 1 CODE PROBLEM. THEY HAVEN'T CALLED THIS A RECALL, BUT THEY ARE CALLING IT A CUSTOMER AWARENESS PROBLEM.
WHIRLPOOL IS SENDING TECHNICIANS OUT NEXT DAY FREE OF CHARGE.
T W
Feb 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 Error Code On Whirlpool Cabrio
I just called Whirlpool...800-253-1301 in USA and a lovely lady informed that there is a recall on the Cabrio Whirlpool washer for the F1 code. We set an appointment and the service call and parts will be free to fix the issue.
Oct 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
122 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
