Question about Pioneer PD-M403 6-Disc CD Changer
Magazine will not eject
When I push the eject buttom the unit makes a noise like it might be trying to eject the magazine but it does not.
SOURCE: pioneer 10 disc changer magazine stuck
Ok well... i haven't been able to troubleshoot the problem much but on most multi-disc players there should be a manual eject button or switch that will release the magazine from the holding unit. Besides that i would refer you to a professional who actually works on Sony multi-disc players
Posted on Dec 02, 2007
  • 44 Answers
SOURCE: Ejecting magazine on Pioneer CDX-fm1257
I have very gently taken a pair of needle nose pliers and grasping the edge of the cartridge that holds the disk carefully work it back into the magazine.
Posted on Jan 09, 2008
Eagleeyes
  • 199 Answers
SOURCE: Pioneer CDX_1280 12 Disc Changer
hi sounds like dirty laser, or dodgy disc.
check your cd for marks. you could try a cd cleaner disc. this may cause it
other wise its a new laser
Mark
Blue ICE
www.blueice-electronics.co.uk
Posted on Feb 24, 2008
SOURCE: Do we have to have the PD-M423 CD magazine for our player
I have 14 magazines (CD holders) that I want to sell. I also have a unit and the remote to sell too.
Posted on Feb 12, 2009
Mr_Wizardtex
  • 205 Answers
SOURCE: cd magazine will not eject,power is connected any
Try holding eject as you turn the unit on? should clear any cd's in the transport then try ejecting. Good luck
Posted on Jul 03, 2009
6 CD cartridge will not eject
If you are getting power to the unit and you hear it clicking and making a sound when you hit the eject button, the this means that a CD is jammed in the track and while it was changing it got stuck and now causes you to see an ERROR message.
What you do is while hitting the eject button, wiggle the CD MAGAZINE up and down and side ways. This will cause the CD to fall into place and your magazine will pop out.
KennyV
Jun 03, 2010 | 1997 Lincoln Continental
My 04 yukon cd changer won't eject the cd. any advise?
if you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Feb 16, 2010 | Car Audio & Video
My original problem WAS that the magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame INSIDE the...
there are small drive belts that provide the power to operate the different parts to eject the CD magazine, i suggest you remove the covers and check these belts for slack/strech, it is a common reason for this problem
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
Hello, I need to manually eject CD magazine from Bose 25 system. The disk inside the amagazine does not work, and ther error E01 appears. At the buttom of the device I see the label "Manually eject CD...
Most of the time you need a paper clip, med sized straighten it out unplug the player and push the pin in a hole about the size of the clip. you will feel a resistance and push thru it. That should open the door.
Jul 03, 2009 | Bose Lifestyle 25 System
Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Dec 01, 2008 | Kenwood KDC-C717 10-Disc CD Changer
No ejection
hi does it make any noise or clicking?
you may have a cd dislodged or mag dammaged.
Mark
Sep 05, 2008 | Clarion DC625 6-Disc CD Changer
Error 1 on alpine cha-s364
Quick Note: It's really helpful to your cause if you make sure you include more information about your system and what you're doing to get an error.
It's also a good idea to make sure you type in your model number correctly - you've typed in cha-s364 (the actual model you're talking about "I think" is a CHA-S634 - please verify!!
Here's a link to the user manual
As for the E-01 Error message on your CD Changer:
The E-01 reading is an error message, usually because the changer magazine is jammed in the changer. To manual eject out the magazine, take a thin plastic ruler (at least 5-1/2" in length) and slip it between the bottom of the magazine and the changer. Now, push in. This will hit a release button in the back. If the magazine does not eject, you will need to send the unit in to be serviced. To locate the nearest authorized service center to you call 1-800-ALPINE-1.
Note: if the magazine is half way out, but jammed, DO NOT try to release the magazine. You will need to send the unit in to be serviced by a technician.
May 29, 2008 | Alpine Car Audio & Video
I receive error msg and cant eject magazine
The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
All the best, Sonia Murray
Nov 28, 2006 | Panasonic CX-DP801 8-Disc CD Changer
Pioneer PD-M403 6-Disc CD Changer Logo
43 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
