I just bought a new computer with a CF card reader. When I insert the card it reads it, and if I use the "safely remove USB memory" feature, if I try another or the same card it does not see it until I restart. The store where I bought the computer said to just remove without the "safely remove button". That works but now it seems like all my cards are messed up. I have reformatted them all, and they just don't seem to do anything. Some will take a pic, then say there is nothing on the card either through the camera or the computer.
I have re-charged batteteis and formatted all cards to no avail.
Comments:
Aug 07, 2006
- no. no switch at all on the cards. I have tried re-formatting a few more times and was able to get 1 to work. Coudl it just be needing a physical cleaning somewhere?
This is a just a thought but some of the better CF cards have a small generally white switch on them. When it is flipped you can not write to or erase of format the cards. If you have the switch try flpping it and see if this changes anything.
ony20 get a lb (iow batt) and the camera will not work. purchased a new batt. with the same results...
(More)
ony20 get a lb (iow batt) and the camera will not work. purchased a new batt. with the same results The 3 volt 2016 batt is not installed in the camera,.. the lid for the 6 volt lith: batt seems secure, I can take the camera apart but so far ai have not been able to put one back together.I am hoping the solution is simple
I have a problem installing driver for canon powershot s20 on windows vista. I just can't seem to...
(More)
I have a problem installing driver for canon powershot s20 on windows vista. I just can't seem to update the driver, and when I connect my camera with the usb cable to the computer nothing happens...please hel.
iam getting the error 28 when i turn on my camera what do i do. please help 6 month daughter need to...
(More)
iam getting the error 28 when i turn on my camera what do i do. please help 6 month daughter need to take pics. it also turns off after the error code comes up
When I try to power off my digital camera the lens will not retract flush with the body like it...
(More)
When I try to power off my digital camera the lens will not retract flush with the body like it should. I can turn the camera on and the lens will extend like normal but I can not focus anymore. Please help.
