Question about Frigidaire Dryers
I have a Frigidaire gallery series dryer.(GEOQ2152ESO). It will spin but will not heat. I suspect blown house fuses in dryer circuit. How do I access and replace fuses ?
  • 550 Answers
The dryer circuit will be clearly labelled in the house box, there will be two fuses or a single two phase breaker for this circuit.
there are not usually electrical fuses as such IN a dryer, there are thermostats to regulate temperature, and a thermal fuse, that cuts the power totally to the heat element if air temperature rises above its melt point.
the element itself has a limited life span and may fuse/burnout.
to test electrical components.
Unplug dryer
open case, by removing the front,
described elsewhere in any of the 'changing belt' threads
locate the thermal cutouts, on the fan housing or exhaust duct and disconnect one wire to isolate it from the rest of the circuit, test with ohmmmeter, no-continuity replace, continuity reconnect wire
I have a Frigidaire gallery - 3aca526.jpg5d18df6.jpg thermal cuttouts look like these ~1inch accross.
locate the heat element and disconnect one wire to isolate it from the rest of the circuit, test with ohmmmeter, no-continuity replace, continuity reconnect wire
while you have the dryer open de-lint the fan and exhaust ducting, most common cause of element or themal fuse failure is air flow restriction
ce0732c.jpg you get a lot of lint out of the fan even when proper cleaning is done, andI have a Frigidaire gallery - 95b69b0.jpgthe ducting right to the exterior walls
95b69b0.jpgthis was the rather extreme result of not cleaning the duct (brainiac placed a wire across the terminals of the burnt out thermal fuse)
Posted on Oct 23, 2008
  • AlmostBob
    AlmostBob Oct 23, 2008
    there are only ~5 different thermal fuses, the local parts guy will have the right one for your dryer, even if it has a different maker name on it, they're mostly the same
Kenmore 110.64622300 not starting
Unplug dryer and check the vent pipe to outside clear it and make sure vent is clear ro outside atmosphere.
take back off of dryer and check fuse. Fuse is located on blower housing next to control thermostat.
3399849-j2rqmywrjn05nkl43ld3f3b0-5-0.jpg If the fuse IS open (blown) then remove the filter housing and clean it as well. I have a home made video I did about heat problem but on my video I show how to check all that stuff: below that is my blog page smack dab full of all manor of stuff pertaining to your dryer. Please let me know if this heps. -PawPaw Dan Webster https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes
Jun 23, 2017 | Kenmore Dryers
Were is the thermal fuse located on the frigidaire fde336res1
It is located on the rear bulkhead upper right hand corner. Ti access it you pop the top with a putty knife and remove the front panel. Get the drum out. I recently worked on one and did a video:
http://www.youtube.com/watch?v=wkog1i53T_k&list=UUKBjalPycKRmo4Mz9vRsydg&index=10&feature=plcp
http://appliancejunk.blogspot.com/2011/08/frigidaire-gallery-dryer-revamped.html
The smaller disk is the fuse. If blown the dryer will not run
Jul 07, 2012 | Frigidaire Dryers
Dryer will not turn
hello check to see if the long pin inside the door has not snaped off if thats ok .then check capacitor next to the motor inside the dryer may have blown
regards
shaun
Mar 01, 2010 | Frigidaire Electric Dryer
Just installed a frigidaire washer/dryer combination. The washer works and the dryer tumbles, but there is no heat for the dryer. Help
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 01, 2010 | Frigidaire GLER642A Electric Dryer
Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Jan 08, 2009 | Frigidaire Dryers
Frigidaire dryer will not heat  runs/tumbles sometimes the heat works & sometimes it doesn't Mdl No. CRGR7900AS2
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Dec 19, 2008 | Frigidaire GLER642A Electric Dryer
Dryer works but won't heat
2 things ,,no heat whats so ever ,sounds like ignitor,, or little heat possible coils )gas)
Nov 29, 2008 | Frigidaire Dryers
Emerso Dyrer doesn't give heat
Your issue is;
"I have an Emerson electric dryer model # RED440SQ0. The dryer spins but there is no help. Thanks for any help. "
Based on the information provided above, I am unable to access my database to provide you with exacting information. An invalid model number was returned... However, I have provided some common solutions to help guide you in your search.
This information is for a generic brand dryer only!
My Solution is:
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
Note: A volt-ohm meter is beneficial in performing electrical tests.
Temperature Switch; make sure a positive heat selection has been made, still no heat, then check these:
Heating element
Thermal fuse
Wiring
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 23, 2008 | Dryers
Frigidaire front loader dryer, Gallery series, blowing cold air only
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further.
Heating element
Thermal fuse
Wiring
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
Jun 23, 2008 | Frigidaire Dryers
Dryers Logo
1,039 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
