Question about Hitachi CML174SXWB (Carbon) 17" LCD Monitor
"auto adjusting" message box won't go away
The "auto adjusting" box flashes continuously on my monitor, no matter what operation is performed. I have tried re-installing the display adapter, but that didn't help. Should I try a new cable? Please help, my eyes are getting very tired of the flickering!
0 characters
1 Points
I have LCD monitor screen & windows xp as operating system.i cannot remove auto adjusting message box. it flashes on screen after every 2-3 seconds & due to this my screen will auto adjust at every...
The message is being created by the monitor not Windows. The only thing you can do is look for the option to disable it on the monitor's menu options. NEC-brand monitors will have something call "Onscreen Notification" which you can disable. Hopefully your BenQ will have a similar option.
Mar 20, 2011 | BenQ FP71G+ 17" LCD Monitor
Computer monitor
If one of those 5 computers has a working monitor,
set the device-resolution to 800-by-600 and the refresh-rate to 60 Hz.
Then, disconnect the "working" monitor, and connect the "problem" monitor.
It should say "auto-adjust", and then it should continue to display that 800-by-600 image.
Try upping the device-resolution to 1024-by-768,
and see if the "problem" monitor will support that resolution.
Try upping the device-resolution to 1280-by-1024,
Nov 06, 2009 | Computer Monitors
Think I fixed it.. My monitor kept flashing autoconfig and shaking a little, so I went to control panel - clicked on system - clicked Hardware - clicked on device manager - clicked display adapters - and updated the driver. Re-booted computer..
So far so good... Fingers Crossed..
Oct 23, 2009 | Acer Computer Monitors
Depends of what seems to be a problem.
If you want to get rid of that message box, appearing by itself, then probably you need to take front panel PCB with buttons and replace "Auto" one, 'cause it's stuck.
If you want to unlock an Auto Adjustment and other functions in your monitor, then press and hold 'Enter' button for 5 seconds.
Sep 14, 2009 | Samsung SyncMaster 17" LCD Monitor
Computer monitor keeps auto adjusting screen
I have a Benq that was continually auto adjusting, I used electronic cleaner spray on all the controls (a good spray) and now there is no problem, suspect the controls were sticking, especially the on/off and the auto adjust button
Dec 20, 2008 | Computer Monitors
Auto Adjust box keeps appearing
check the section of command.check frontpanel switchs and components related with it. if it dont work then change memory ic.
Mar 21, 2008 | Samsung SyncMaster 174V 17" Flat Panel LCD...
720n problem
better call the company. it's may be a processor problem..
Feb 21, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung 731N Auto Adjustment
I'm having the same problem. Started three days ago. Really annoying. First I downloaded a driver because that was reccommended over plug and play. But that did not fix the problem. I ended up pressing the menu key (1st on left) and while holding it down I wedged a little piece of paper to hold the key down and the popup menu's have stopped. The box can be the brightness/contrast or auto/image reset/color reset ...
it doesn't matter, they all popup after pressing buttons left and right. Have no answer to correct the problem but at least I can now compute without these stupid menus.
Dec 27, 2007 | Computer Monitors
Hitachi CML174SXWB (Carbon) 17" LCD Monitor Logo
233 people viewed this question
Top Hitachi Computer Monitors Experts
james allen
james allen
Are you a Hitachi Computer Monitor Expert? Answer questions, earn points and help others
