I have a 50" Panasonic Plasma TV. It displays parallel lines with "system checking" display for 5 minutes and then gets snow flakes. Any help would be appreciated.
    Genius:
  • 2,920 Answers
It sounds like the tuner is out on the tv
Posted on Oct 23, 2008
I got a 2017 freighighner cascadia and my optimise idle is set but doesnt turn on
Make sure you are following these steps:
1. Start the truck.
2. Make sure parking break is set, hood is closed, and the shifter is in neutral and set to the high side range.
3. Press the cruise button on
4. The orange "IDLE MGMT" light will flash for about 2 minutes.
5. When the truck is ready to shut off the red "stop engine" light and the orange "check engine" light will flash and the "IDLE MGMT" light will go solid and truck will shut off. At this moment low battery voltage or low oil temperature will cause the truck to re-start.
6. In-cab thermostat will not cause truck to re-start unless a button on the thermostat is pressed at this point. Press the snow flake/heat wave button to activate the in-cab thermostat. The lcd will display a snow flake or heat wave, press the button again if desired setting is not displayed. Once desired setting(cool - snow flake, heat - heat wave) is displayed, use the up and down arrows to choose you desired temperature setting.
Truck will not restart until the thermostat is either 7 degrees below or above the selected thermostat setting. Hope this helps.
Nov 22, 2017 | Computers & Internet
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Only the right side of my Panasonic Plasma TV (TC-P50UT50) is displaying. The left is is black with some white flickering lights. Sound and video on the right side are perfect.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 01, 2015 | Panasonic Viera 50" Class 1080p Full HD 3D...
PT53WX52F wont turn on, blinks 5 times.
5 blinks to plasma display denotes a fault with its main power supply regulator board. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. Blinking codes & fault detecion procedure to Panasonic Plasma display is given in detail.google.com/+GopakumarGopalan
Nov 01, 2013 | Panasonic TC-P50G15 50 in. Plasma HDTV
Have a Samsung 50" plasma tv with horizontal black
There are two possibilities for this fault. If COF module has any loose contact, or, display itself. If you wish to get more details about these type of fault to Plasma display, check the link given here. It has screen-shots of defective plasma dislay. Compare them to that of your TVs' and make sure. http://electronicshelponline.blogspot.com/ View it in Timslide option.
Jun 30, 2013 | Televison & Video
Screen dims slightly suddenly
Hi.
Plasma display suddenly dimming down is usually symptom of a faulty sustain board. Sustain boards and other parts like the PSU must be tested before replacing any component.
Dec 12, 2011 | Panasonic TCP50S30 50 50 Plasma TV
My Panasonic Plasma TV Model #TH50PX600 Ser # LC61920453 has vertcail lines on the left hand side of the TV. Lines cover 50% of screen. You can still see the pricture in the back ground. Is this due to a...
It is possible that it is a bad D board, however it is not likely based on experience.
But that's your best shot anyway.
I'd order one and try it.
The other alternatives are bad power to the board or bad plasma display, specifically the buffer ICs that are embedded in the display.
May 31, 2011 | Panasonic 50 in. Plasma TV
Red lines on plasma TV
It may be because the tv is unable to display the signal coming in....
Feb 17, 2009 | Panasonic TH-50XVS30U 50 in. Plasma HDTV
Black bold line on panasonic plasma screen
Hey,
Your problem goes outside of my expertice, I would recommend you ask http://www.fixya.com/users/slinteriors Slinteriors for help, send him the problem, hes one of the best TV experts we have on this website I'm sure he can solve your problem
Thanks,
Ekse
Aug 29, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
