Question about KitchenAid Microwave Ovens
Microwave stopped working
KitchenAid Superba model KEMS377D / KEMS307D - microwave oven combo. A few seconds after starting to nuke something in the microwave, it stopped, and the message "door open" flashed on the display. Now it doesn't work. The light does not come on when you open the door, and when you hit any of the microwave buttons, it beeps 3 times. We purchased it in 2000. I switched off the circuit breaker, and then back on after a minute to see if that would reset it, and no luck. The oven works fine. Any idea what is wrong, what needs to be done to fix, and how much (ballpark) it will cost for parts/labor?
  • KitchenAid Master
  • 3,051 Answers
Hello there and welcome to fixya
This is a fairly common issue with microwaves
Normally the issue that you are dealing with is that the dor switch has went bad or the electrical wiring may be getting loose so what i would do is first remove the outer shell of the microwavethen get to the door switch and find the wires that are going from it to the connection poing then make a note of where the wires are connected at then remove the wires and test using ohm meter set at the lowest setting you should be getting a ol reading when the door is open then shut the door and you should show a little bit of continuity when the door is shut something like 020 or something like that however if it does not move or the numbers are really high then it should be replaced ok
I have posted a link here for you to follow on how to test it and several other parts ok http://www.ApplianceRepairLesson.com
Posted on Feb 10, 2012
4 Suggested Answers
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Posted on Mar 26, 2009
najah
  • 180 Answers
SOURCE: How do you replace the lamp in a Kitchenaid
open the top cover then you can see the bulb on the right side of the oven, just remove the lamp and replace it by a similar one. you can try to get the lamp from any electrical shop with the same size and same rating.
Posted on Jul 14, 2009
localwonder
  • 6784 Answers
SOURCE: Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Posted on Dec 22, 2009
Microwave Ovens Logo
226 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
