Question about HP Office Equipment & Supplies
Can't find a power supply adapter for hp 5400c Scanjet - should be 12VDC ? Wish I knew how to modify to accept a hp 4400c Power Adapter
  • chuckywucky Oct 23, 2008
    ginko guru came through in a dash FLASH - provided an
    excellent solution at the right mice price - Many Thanks
    You is a genius guru and are one yes yup Uh Huh AOK !
DO NOT buy anything from Impactcomputers.com !!! Link for HP AC power module goes to this website, they are thieves. Send wrong parts, charge you to ship it back, and charge huge restocking fees. Customer service at this site are expert at lying to you. Google "complaints for Impactcomputers.com" and you will see they have 96 complaints to the better business bureau in just a few months. You will never get the part you need from them, they will rip you off.
Posted on Mar 06, 2010
  • HP Master
  • 19,396 Answers
Better to buy the original part.
The price for the replacement depends on where do you live.
Here is the worldwide one :
Hewlett-Packard Low power AC power module (Brick Type) - C8517-84204 (worldwide delivery)
Hewlett-Packard C8517-84204 (UK )
To find the adapter just insert part number in google and get the sellers.
Worldwide operation (100V-240V) Low power - part number : C8517-84204
UK and Ir only operation (100V-240V) Low power - part number : C8517-84202
Europe, excluding UK and Ir operation (220V) Low power - part number : C8517-84201
Posted on Oct 23, 2008
My HP Scanjet 5400C Scanner has decided to stop working. The 12 volt mains transformer feels cold and no light comes on the scanner. It appears that the transformer is US. Where can I buy a replacement
You can probably get this from HP. See http://h20141.www2.hp.com/Hpparts/Search_Multi_Product.aspx?mscssid=42F39AE6AD6B4EFBBC921EC42BADCDE3&SearchCriteria=Scanjet~5400C and select your model. There are 4 versions of the ScanJet 5400C listed. Then select power module in the drop down menu and click on the arrow; power cords are listed separately. Alternatively, click on the arrow for show all parts. The listings are clearly labeled for the country electrical system with which a given part is compatible.
I hope this helps.
Jan 08, 2011 | HP Scanjet 5400c Flatbed Scanner
What voltage should be read on each pin of the power adapter?
hello ,, this information is based on ScanJet 5400C - (C8517V) -- if yours is other p/n, let me know
North American use , C8517-84200, Low power AC power module (Wall Mount Type) - 100-120VAC, 60Hz - Detachable power cord not needed (USA, Canada) - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
European use , C8517-84201, Low power AC power module (Wall Mount Type) - 200-240VAC - Detachable power cord not needed (Europe) - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
Worldwide use , C8517-84201, Low power AC power module (Brick Type) - 100-240V input - Requires a 3-wire detachable power cord - For worldwide operation - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
i hope thsi helps -- if it does, please rate my service
Nov 13, 2010 | HP Scanjet 5400c Flatbed Scanner
I need a power cord for an HP Scanjet 5400c
If it's just the power cord you need, monoprice.com has excellent prices. Here's the cord listing:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10228&cs_id=1022806&p_id=1307&seq=1&format=2
If you actually need the entire power adapter, that's a bit more complicated. There are a lot of online vendors, but I'd need to know your location and "risk tolerance" to give you the best purchasing options.
Oct 25, 2010 | HP Scanjet 5400c Flatbed Scanner
What power supply is needed for hp scanjet 2400
It is depends on your scanner power adapter and where u purchase the scanner from. Here if your scanner is from US then the adapter power input should be 100-120V 60Hz AC, if your scanner is from Euro, UK or Australia, the it should be 200-240V 50Hz AC, while if your scanner is from others place that not listed above then it should be 100-240V 50-60Hz AC.
But the best way is look at your adapter itself, u'll notice the power input and output from the adapter sticker.
If you lost your adapter then be sure to purchase 1 that can output a 12 VDC, 340mA, 4.22W adapter to the scanner.
YBC (/\)
Oct 20, 2009 | HP ScanJet 2400 Flatbed Scanner
Scanjet 4300C
Hope this helps, but there's no specific model number, but here's a description:
Round barrel connecter with a positive center. Voltage regulator, power supply, powersupply, inverter, adaptor, adapter, transformer INPUT: AC 100V and OUTPUT: +12VDC/1.25A (12 Volt 1250mA)
And, a photo:
Aug 25, 2009 | Office Equipment & Supplies
Unsure about power supply
Don't know if you've got round this by now but the supply needs to be 12v 1A with the inner positive
Dec 21, 2008 | HP Scanjet 4400c Flatbed Scanner
Loss of power
I have a similar scanner, scanjet 5470c which is using the same power supply as 5400c and 5490c
2 weeks ago the scanner stopped working, yesterday i checked the scanner and found out that there was no power (12V)
the power module (black box) going into the 220V is a plastic box without service possibility. I took a screwdriver and a hammer to open the box. Inside the box i found a lot of electronics and yes a Fuse aswell. I did not have spare fuses, so like all bad boys i replaced the fuse with a wire, and guess what? .. yep I blew several main fuses in the house and now have a burned-out power supply.
the power module is still available at the HP Parts Store the part number is C8517-84201 i see a list price of 23 EUR
Before a buy a new power module I will first test the scanner with a spare 12VDC and see if he still works.
I will come back and tell you if it works...
Feb 17, 2007 | HP Scanjet 5400c Flatbed Scanner
166 people viewed this question
Seeker5211
Seeker5211
