Question about Graco Baby Gear
How do you get the vibration unit to work - Graco Baby Gear
  • 396 Answers
Be aware that Most Graco/Simplicity Cribs and Bassinets, especially those with vibration, have been recalled. Please review the CPSC link below and determine if yours is on recall. If so, simply take it to Walmart for a full refund (usually around $100) NO RECEIPT REQUIRED.
CPSC Graco/Simplicity Bassinet Recall
Posted on Feb 14, 2012
Vibrates real bad in spin mode.
Check to see if the washer is level, and adjust the leveling legs if necessary. Always lock the legs in place after adjustment to keep them from getting loose as they do work themselves loose during heavy vibration conditions.
The following items could cause the vibration problem:
1. Clutch assembly
2. Vibration dampers that support the tub. Should one or more be faulty, always replace all four simultaneously.
Feb 24, 2016 | LG WFT1071TP Top Load Washer
It is loud vibrating when comp. runs if I tip the unit up 3or4 inches it stops vibating is this ok too run this way?
No, not really. As the unit has to be in a level position to operate properly and not overflow.
If the unit is sitting on carpet, this will often times cause the vibration noise. I don't know why, but it does and it does with my 4 year old LG unit. I have noticed, that once the tank reaches the 1/2 full point, it will vibrate sometimes. I solved the problem by firmly smacking the left & right sides of cabinet at the same time, with my open hands. The vibration stops immediately and continues to run until it shuts off because, the humidity extraction level has been reached or the tank is Full & needs to be emptied.
It's a simple solution, but it works. I hope it works for you and thanks for choosing FixYa.
Aug 23, 2011 | LG LHD459EL Dehumidifier
I have Sony T-200 for more than 2yrs. It has been working alright. Now when it is switched on it vibrates and the picture you get is out of focus?There is no vibration when viewing pictures.
hi, your camera has IS unit get defective cause vibrate noise. and out of focus. It will require realignment or lens unit assemble or replacement of the lens unit. your local repair shop would charge around $65 to 135 depend on what they really want to charge. Good luck with you and best regard!
May 22, 2011 | Sony Cybershot DSC-T200 Digital Camera
RV ac is vibrating
Take a good look at fan blade for a crack in one or more, as well as turn unit on & watch for vibration , then take a look at mount bushings on all items. Also with fan off (obviously) check shaft for movement, side to side, up & down, in & out. Your gasket between roof should only be compressed approx half it's original thickness. Some manufacturers tighten them down too much and can be a source of vibration as well. Not expensive or hard to change. Don't forget blower wheel as well.
Jul 21, 2009 | Dometic Rooftop RV Air Conditioner
The unit vibrates and has a pulsing sound. I have
These things tend to make a bit of noise, some more than others. You will not be able to do much about the internal produced noise but you can do a lot with the resulting vibration noise.
While the unit is running, take a few minutes and actually touch the unit ALL OVER, you are listing for any vibration noise to cease or be less so where you are touching. This includes the collection pan and the filter. Slightly Tilt the unit in all directions. Make sure that the door to the collection pan is closed properly. Take a few strips of the peel-off adhesive sided thin window/door insulation and apply to the bottom of the collector pan, if it sits ON the bottom of the unit. Place an inch or two thick blocks of foam rubber under each corner of the unit. Make sure the unit is level. Some where along here you will stifle some of, or maybe even most of the noise.
Good luck. :)
May 06, 2009 | Dehumidifiers
Motorola T6550 pair.
I can see where this feature can seem somewhat inconsistent. But if you think of it like a phone ringing, it is easier to understand. Once you have answered the phone, the phone stops ringing. And the person who called you never experiences a ring on their end.
VibraCall® Alert
Page 26: VibraCall is a vibrating alert that notifies you that your radio is receiving a message. This is useful in noisy environments. When the alert is on, the radio
vibrates once every 30 seconds when you receive a message on the channel and
code you set.
• To turn vibrating alerts on, press menu until the vibrating radio symbol is displayed, then press the plus (+) button to display the letter Y for Yes.
• To turn vibrating alerts off, press menu until the vibrating radio symbol is displayed, then press the minus (-) button until the minus symbol (-) is displayed.
Dec 10, 2008 | Motorola Talkabout T6550 (7 Channels)...
Midland radio battery pack constant vibrate
Hello pjbracht, I just responed to a duplicate of your problem. If they are new, return the battiers and confirm they are "by the book" replacements. If so ask for replacemrnts with a higher mAhr. It is not correct for vibration from a battery pack, lead, NiCad, Ni-MH, period.
Nov 01, 2008 | Midland Radio Communications
My washer vibrates so much it actually moves the appliance. Yes, it is level. I also took the clothes out of the washer and tried the spin cycle with out clothes in it and it still vibrates.
If you call LG they actually have some rubber pads to go under the unit to stop it from sliding and it also helps with the vibrations. Part number is 4620ER4002B.
I know of people who have also gotten a thick rubber mat, stal mat, and put it under the unit. They claim that it works wonderfully.
Sgt 48
May 30, 2008 | Maytag Washing Machines
80 Series top loader excessive vibration and noise on spin
check the screw feet, on the front corners, one may be not screwed down far enough to be 'tight' to the floor allowing a small movement that makes a lot of noise, halting under pressure suggests this is the case
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
VIBRATING ALERT DOESNT WORK
Open the unit and clean the contact on the vibra and check the vibra to see if its stil ok. Use an eraser to clean the contact.
Jul 24, 2006 | Nokia 3220
Baby Gear Logo
319 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
