Question about HEALTHRIDER R65 Treadmill
How to unfold healthrider treadmill - HEALTHRIDER R65 Treadmill
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: healthrider r60 stops when it reaches 4mph.
Unplug unit and remove the motor shroud you will have to do DC Amp Measurement.
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
Posted on Jun 28, 2010
ercupa190
  • 12223 Answers
SOURCE: The incline on my HEALTHRIDER
1) tight the flexible cord from keypanel vs display board
2)tight the display board vs lower board(main motor board)
3)Test the main motor board(faulty to worn deck belt)
4)INCLINATION motor burn.
5)Adjust Pot from the inclination motor
6) the gear slip adjust or repair.
see the block diagram
Posted on Dec 13, 2011
How do I unfold the health rider h75t
Guys ,
Try rewarding your body by feeding it isagenix
Warm regards
Isagenix Consultant
www.msranderson.isagenix.com
The Isagenix Wealth Creation solution
Cleanse for Life
The Isagenix Weight Loss Solution
The Official Site of Isagenix International
Jan 26, 2014 | HEALTHRIDER H75T Treadmill
I need to replace the motor belt but i can't remove the front roller of my H140t Healthrider treadmill
There is one screw in the front roller
  1. Loosen the rear roller
  2. Remove drive belt
  3. Remove the 1 screw in front roller
  4. Pull roller out
Jan 01, 2014 | FreeMotion HealthRider "Club" Series H140t...
I have a HealthRider S300i treadmill, but unfortunately, I don't have the included allen wrench. So far I've been unable to figure out what size allen wrench I need. Any idea?
you can try to rent a set at AutoZone. when you return it they will give your money back. try standard and metric. depending on manufacturer of treadmill.
Feb 09, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
HEALTHRIDER R65 Treadmill Logo
56 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
