Question about GE GSC3500RWW Portable Dishwasher
Ge portable dishwasher has no power but outlet works fine
Has no power but the outlet works with other appliances. It worked fine two days ago.
3 Suggested Answers
  • 209 Answers
SOURCE: DISHWASHER WILL NOT POWER ON AND THERE IS POWER TO THE OUTLET
more than likely the door catch switch or the on off button, check these 2 first
Posted on Oct 15, 2007
MNTECH
  • 1543 Answers
SOURCE: GE Profile GSD4010202AA Built in Dishwasher acts as if no power
1. turn breaker off to diswasher. 2. remove bottom access cover. 3. remove cover over electrical connection box on right side. 4. hold each wire nut connector and firmly tug on one wire at at time to make sure none of the wires pull out of the wire connecor nuts. A loose connection here is more common than you might think.
If those are all OK, turn breaker back on and make sure you have power there. (120 volts black to white) If that was OK, then check door latch switch inside door at the top center and wires passing through door at the bottom of the door.
Posted on Jul 26, 2010
My GE Portable dishwasher won't fill.
Possibilities:
Water off.
Blocked water filter
Water solenoid valve not actuating
Water solenoid not getting power
Not getting power could be:
Stuck pressure switch,
Programmer not working
Broken lead
Feb 13, 2015 | GE GSC3500RWW Portable Dishwasher
Hi I have a GE model GSC3500ROOWW witch without any previous issue won't power up at all I checked all the normal causes the breaker is good tried different outlets and still nothing this model is a...
I once had a portable ge dishwasher that burned up at the spade connectors attaching the power cord to the internals on the unit. Might be a good place to start
Aug 25, 2013 | Dishwashers
My microwave made a funny noice a couple of nights ago, but continued to work fine after that but now it's completely dead. Checked the breaker and it's fine. Any ideas?
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARRAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 05, 2011 | GE JE1640 Microwave Oven
Shut off
Start by replacing the power supply fuse. Can be found in the area of the control panel. Use a 15 or 20 amp fuse, most appliance parts stores carry them.If it goes again, then you should have it looked at by a professional.
Jun 05, 2009 | GE JVM2050 Microwave Oven
The water doesn't stay at the bottom of Dishwasher & The detergent doesn'e get totaly emptied out from detergent Tray. It looks like the the residue remain in the Dishwasher & On Dishes too. Please, help...
hi there,
no indication that machine is not working,is there any power supply,check the power source,circuit breaker switch on.
Step 1: Check to make sure it's receiving power. If the unit plugs into a wall outlet, check the cord, the plug, and the outlet to make sure they're functioning properly. Also check the switch that controls the outlet to make sure it's turned on. Most built-in dishwashers are wired directly into a circuit. Check the main entrance panel for a blown fuse or tripped circuit breaker, and restore the circuit. If your home is an older one, the dishwasher may be wired to a separate entrance panel; look for a blown fuse or breaker at this panel, and restore the circuit.
Step 2: If the circuit is receiving power, and the wall outlet is controlled by a switch, the switch may be faulty. Test the switch with a voltage tester. Take off the switch cover plate and place one probe of the tester on one terminal and the other probe on the other terminal. If the tester bulb lights, the switch is functioning. If it doesn't light, the switch is faulty. Replace the switch with a new one of the same type.
this should be done by appliance technician,but if you have knowledge on this check it out.regads have a nice day,dont forget to rate me thank's
Apr 30, 2009 | GE 25 in. Profile PDW8200J Built-in...
I purchased a diswasher (Hotpoint)about 1-1.5 years ago. It's model # is HDA3400G02CC and its SS# is TH887451Y. I don't think I registered it. No Matter, Two days ago, my garbage disposal stopped...
I purchased your service (telephone support) and the dishwasher expert contacted me. We discussed the issue, he made recommendations. I followed his advise and solved the problem. Before I could recontact him, he called to follow up on my progress. His advise was straight forward and correct and today my wife is happy to have her dishwasher working again.
Thank you,
Richard from Missouri
May 25, 2008 | GE Dishwashers
Oct 13, 2007 | GE 24 in. PDW9880LSS Stainless Steel...
Portable dishwasher G E
remove the drain pipe form the waste outlet and lay it down lower than the bottom of the dishwasher so it drains out with gravity simple really
Sep 26, 2007 | Dishwashers
GE GSC3500RWW Portable Dishwasher Logo
160 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
