Question about Proview MH422HUBD 42 in. Plasma Television
Shaaded area on screen - Proview MH422HUBD 42 in. Plasma Television
  • 3 Answers
If its shaded area on left and right it's because of settings with your tv or cable box, it's usually hd channels showing sd show. Hope that helps
Posted on Feb 10, 2012
My korg N364 is out of tune. how do i fix it?
hello sir,
THIS IS SOFT RESET; FACTORY MUTE PARAMETERS WILL BE LOADED INTO ... ART, MULTIVERB LTX, No factory reset, remove battery for more than 5 hours. .... KORG, N364, HOLD ENTER AND 7, THEN POWER ON. KORG .... ROLAND, D-550, TUNE/FUNCTION AND MIDI DATA INIT: HOLD PATCH BANK 2,
thanks from: SHAAD GONDEKAR
Feb 21, 2017 | Korg Music
What can be done to repair picture to my TV
Vertical scan output section circuit should be checked. Contact any service technician.
Aug 30, 2014 | Toshiba CF32H40 32" TV
Lots of dots on the screen. In light areas they are black dots, in light areas they are dark dots
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years, and the price is USD200
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 27, 2014 | NEC Lamp for NP215 Projector
2 inch band across the bottom of screen
Downloading programs would not cause the type of problem you're having. It should be a hardware issue only.
1.The bottom area of your screen is close to a small curcuit panel behind the bottom plastic border of the screen frame. This little panel/bar is called the Screen Inverter. If its connection plug has loosened it could be the culprit.
2. The Display Cable behind the screen panel has become partially unplugged or damaged in some way at the top of the screen, or, it has looseened at its plug connector just underneath the back edge of the power strip panel/keybaord area so that pressure applied to the bottom of the screen frame makes it connect correctly.
3. The Screen Panel itself is failing.
These are the 3 areas I'd say you should have a laptop repair tech look at locally in your area.
Best of Luck
Jul 13, 2010 | IBM Lenovo ThinkPad T60p Notebook
Stained / darkened image area on about 1/3 of screen
first how old is the tv with your first and second generation flat screens and plasma tvs alot of the logos have burned into the bottom corners of the screen and after awhile they burn so much in it grows to bigger portion of the screen and unfortuneatly there is nothing you can really do for this until its time to buy a new bulb if lcd for the tv sorry
May 14, 2009 | Westinghouse LVM-37w3 Television
Monitor
This is probably a dead pixel area and there may not be anything that can be done other than replacing the screen. This could also be a stale area in the liquid crystal. Try massaging the area firmly, just hard enough to make the screen change color, but not too hard as to make it turn black. If it's a stale area this should refresh it. If it's a dead area, then I'm afraid replacement is the only option.
Jul 19, 2008 | Computers & Internet
"Finger Print" sized shaded area on screen
A shaded or dark spot on the screen is usually a bad pixel area and is caused by being hit or pressed to hard in that area. It could also be that the liquid crystal (LC in the LCD) in that area has become stagnant, try rubbing the area and around the area pressing firmly, just enough to see a color change in the screen area, but not too hard that the area turns black. Rubbing the area will move the liquid crystal around and sometimes refreshes a darkened area. If rubbing doesn't work, then it's a bad pixel area, and will eventually become a dead pixel area with time.
Jul 04, 2008 | Acer Aspire 5050-3242 Notebook
Difference in contrast noticed when screen is black
If it is an LCD TV, then there may be lighter areas due to the location of the display backlights.
Areas closest to the backlights will be slightly lighter.
Feb 18, 2008 | Televison & Video
Can I add another 512MB of memory to my A105 satellite toshiba
i dont know as much about laptops but you should be able to get the 512MB. to replace it look on the bottom on the laptop there should be somewhere down there that you can open up the to put it in.
Nov 22, 2007 | Toshiba Satellite A105 Notebook
Proview MH422HUBD 42 in. Plasma Television Logo
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Tony
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
