Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Had the main tube replaced in 2008 bought tv in 2003
  • 3 Answers
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Posted on Feb 10, 2012
How mch is a 42 inch plasma screen for sanyo dp42746
It will cost around 2/3rd of the total cost of a new TV.
Jun 20, 2013 | Televison & Video
32 inch,plasma,will not turn on
Your TV has obviously shrunk by 10 inches.
Other than that, what symptoms did it show before it died. Also what model number is it.
Mar 25, 2011 | NEC - 42" Commercial Plasma Screen ***(no...
My 8yr old hitachi 36" tv keeps going in and out.
This is what is called the vertical IC, This is a flat ic on a heatsink and it could be label LA-______ something, I don't remember if it's 1601 location or what. also change out caps, like 100uf and 220uf, around this ic also loose connection are a problem with this too.
Mar 01, 2011 | Hitachi 36CX39B 36" TV
Printing files smaller than actual?
Because the 5500 does not print to the edge of the paper it will auto shrink the image to fit the paper ( a 36 inch wide image will shrink to 35.45" when 36" paper is used). Your image will need to be at least 0.55" narrower than the width of your paper to avoid this. so: Crop the image if you can, or use wider stock.
Feb 03, 2010 | HP Designjet 5500 (42 in.) InkJet Printer
I have a 2001 sony wega 36 inches and the channels
If you are comfortable with working inside the set where there are potentially dangerous high voltages present, you can probably fix this easily. Open up the back and remove it. Plug the set back in and turn it on. In the lower right hand side will be the flyback transformer (large red wire coming out of the top and going to the side of the picture tube). DO NOT TOUCH IT!!! On the back of the flyback should be 2 "knobs". One will be marked screen and the other focus. Carefully adjust the focus until the picture is clear. When you do this, go beyond the clear point and work the control back and forth a few times before settling in to the focused spot.
That should resolve the problem.
Dan
Apr 07, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
42 inch screen
Did you measure diagonally from corner to corner? This is usually how all manufacturers quote screen size. Hope this helps
Dec 07, 2008 | Polaroid FLM-4201 42 in. LCD Television
Toshiba 36a43 no picture
reset the settings using the user manual then the problem will be solved
May 13, 2008 | Toshiba 36A43 36" TV
Vision 42 inches plasma tv
It sounds like there is a problem with the tuner inside the television. Your best bet is to send it in for service.
Jan 30, 2008 | Vision HDV-42P2 Television
Toshiba 36A40 36" TV / Chassis No: TAC 0011
Bad capacitor in vertical circuit + possible vertical output IC
damage.If you can identify part locations and solder.....?
May 24, 2007 | Toshiba 36A40 36" TV
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
