Question about Whirlpool Dryers
My Whirlpool AWZ7303 Condensor dryer wont dry the clothes. It heats up, and you can see the steam on the clothes. I think that its not extracting the moisture properly. The water collector does get full but its taking forever to dry a load.
  • KEVRSP Oct 24, 2008
    Thanks a mill, Il have a look at that and come back and let you know.
    Much appreciated
  • 147 Answers
Your vent hose is crimped or clogged. Take hose off and see if air is coming out. Bet your dryer has been push against the wall and crimped the hose. This is the problem 8 out 10 time but if it isnt let me know. There is more tricks.
Posted on Oct 23, 2008
  • butch welch Oct 24, 2008
    Two weeks ago my son had the same problem, heating uip, not drying and it was the belt had broken.Very simple and cheap to fix..
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
Oct 29, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
My whirlpool electric dryer WED5560SQ0 takes an extremely long time to dry, almost like it steams
it defne sounds like one or more of your heating elements is faulty , try a simple continuity test on them
Feb 12, 2012 | Whirlpool Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    I have a whirlpool dryer model AWZ 3513 and the filter light is on but the filter is spotless and I have cleaned out the extract tube
    If the ambient air temperature is below 10 Degrees C the drier will not work and I think the filter light is a warning for the temperature as well.
    Nov 29, 2010 | Whirlpool AWZ7303 Electric Dryer
    My whirlpool awz7303 is not get hot so there for my clothes are not drying. i have checked the filter, water container and the heat exchange they are all clean and empty but the filter indicator light is...
    Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
    Sep 19, 2010 | Whirlpool AWZ7303 Electric Dryer
    Dryer heats up but does not dry clothes completely after 60 minute cycle
    try giving them an extra spin in washer I do this all the time extracts a lot more moisture out of your clothes and cuts dryer time as well
    Dec 18, 2009 | Whirlpool LEQ9858P Electric Dryer
    Does not heat
    "Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
    I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
    Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
    Oct 13, 2008 | LG DLE2514 Electric Dryer
    Dryers Logo
    175 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
