Question about Grohe Plumbing
How to remove a Grohe 0405-03 faucet
Can't remove Grohe Faucet from granite counter top
4 Suggested Answers
  • 349 Answers
SOURCE: Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
Posted on May 24, 2010
packrat1948
  • 528 Answers
SOURCE: the shank of the faucet
A lot of the faucet manufactures have not kept up with the new counter top innovations out there so I would say you need to pick out a new faucet that has an extended shank. Short of counter sinking the hole from the bottom of the sink top the above is your only out.
Posted on Feb 08, 2011
  • 2841 Answers
SOURCE: The base of my Grohe faucet, where the faucet goes
You are correct. You need a special tool that the manufacture calls a fitting key. Without this key you cannot tighten the faucet to the counter top. Look at this diagram of how it is installed and you can see what the key (G) looks like. You will also need this key to remove the sprayer head to clean it.
http://www.groheamerica.com/lib/1/tpi/1311700.pdf
Call the person who installed the faucet and ask them what they did with the key. Look around after you see what it looks like and you may find it. Sorta looks like an old outdoor faucet handle. You can contact Grohe for a replacement key from this link.
http://www.groheamerica.com/en/contact-grohe/tech-email/m/25_8195/page/modules/contact/index.php?topic=kpprodukte
Posted on Jul 26, 2011
Grohe alira loose on granite counter
Needs to be tightened from under the sink, may need a right angle faucet wrench, they are about $10, or you can try and snug it up by hand, hope this helps?
Aug 31, 2014 | Grohe Alira Pull-Out Kitchen Faucet S....
Why is my grohe alira kitchen faucet loose
There is a nut up under the counter its hard to see but tighten that . Most faucets come with a special tool fo hat but can be done with wrench
Why is my grohe alira kitchen faucet loose on a granite counter
Probably a loose fixture nut under the counter behind the sink.
Yeah ya gotta pull out everything and crawl up into the cabinet on your back and see if the nut (right up at the granite, above the hot and cold inlet pipes) is loose. If it is THEN you'll need to tighten it. Wrench, slip-joint pliers or a basin wrench. (probably basin wrench which is a specialized tool made for reaching up into tight places)
The shank of the faucet is an 1 1/4 inches long and the granite counter top is 1 1/4 inches thick. cannot tighten nut to hold faucet in place
Feb 08, 2011 | Fontaine Plumbing
The base of the faucet which fastens to the top of the granite is loose and moves around. Is there a nut under the faucet that tightens to keep it firm to the granite? How do I fix this?
yes there is, with a pair of slip joints you can tighten from underneath, it is above the supply line, the best thing to do is turn off the water, disconnect the supply line and tighten the nut, then reconnect the supply line and turn back on the water. Good Luck Tim
Oct 31, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
May 22, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Loose Grohe kitchen faucet
there are mounting plates underneath the counter which fasten the faucet to the counter.This unit will need a small allen wrench if memory serves me correctly...keep in mind that all moen faucets are lifetime guranteed and alot of folks do not take advantage of this amazing warranty which makes these the most desirable faucet on the market.however the need to tighten this faucet prob isnt a warranty replacement procedure but can be determined once mounting items and faucet is inspected...good luck
Jun 28, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe ladylux cafe faucet removal
You will need a Grohe Fitting Key to insert into the fixing tube (which is the area after you have removed the Handspray and the Fit spout) and turn counter clock wise. If you don't have Fitting Key, call Grohe at 630-582-7711
Jan 14, 2009 | Plumbing
Plumbing Logo
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
