Question about Whirlpool Washing Machines
WHAT IS MATCHING WASHER TO WHIRLPOOL DRYER SEDX600JQ0
Kirkland Signature Washing Machine by Whirlpool won't spin. Has no model or serial number plate. The matching dryer is model SEDX600JQ0 ....ANYONE KNOW THE MODEL NUMBER NUMBER FOR THE MATCHING WASHING MACHINE?
gittos73
  • 244 Answers
SOURCE: Washing Machine
more than likely your carbon brushes which are situated in the motor under the outer drum these are held in by 2 star screws and are covered in a plastic casing if under 8ml in length then they need replacing as when new they are about 20ml in length change these and it will work let me know how u go on m8
Posted on Sep 29, 2007
SOURCE: Kirkland Signature by Whirlpool Washer
There could be 2 possible issues, one, the simplest is the switch activated by the lid, look for a plastic "prong" sticking out from the lid, see where it goes and find a switch, use sometime of similar size and see if you can activate it. If that is eliminated then it is a plastic coupling broken, quite involve, need to remove the back lower section and inspect for this, Had both these issues myself.
Posted on Apr 01, 2008
SOURCE: Whirlpool dryer will not heat properly
my dryer gives off heat when no close are in it. but as soon i put close in,the dryer will not heat up.
Posted on Mar 15, 2009
maddogsteve1
  • 18 Answers
SOURCE: My Kirkland Signature Whirlpool Washer will not agitate or spin
broken coupler. device between motor and gearcase, look under washer behind the motor for small plastic and rubber coupler. may be worn or broken. cheap part/fairly simple fix. parts house will run ou through the process or i can provide details when you are ready.
Posted on May 25, 2009
  • 132 Answers
SOURCE: whirlpool washing machine won`t spin or pump out
1-check the drain hose maybe cloged 2-check the drain filter maybe filed with materials 3- check no spin mode maybe you selected thank you
Posted on Jun 08, 2009
Washer won't drain.
It is possible that your lid switch is defective. Bypass the switch and try again-Please unplug your machine while you bypass switch. If it still does not drain the I would suspect your timer.
Lid switch Part# 3949247
Timer Part# 3955651
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool Washing Machines
Whirlpool washer model LSR5232LQ0 won't drain. just stops. is there way to cause drain?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 22, 2011 | Whirlpool Washing Machines
Won't spin
heatman101
Jul 17, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My Kirkland Signature Whirlpool Washer will not agitate or spin and the motor makes a load noise (like something rattling) when the tub should be moving. but it does drain water.
May 24, 2009 | Washing Machines
Clothes dryer doesn't spin
The way most domestic clothes dryers are made, it's usually hard to determine that the heating part works without the drum turning.
But, chances are, the drum belt is broken.
Please give the specific model number of your unit for a more complete response.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
