Question about Craftsman Saws
Bearing for rm872?
Where can I get replacement bearing for circular saw motor RM872
3 Suggested Answers
lfo16
  • 10 Answers
SOURCE: Can the rm871 motor be replaced with rm872 motor
ooooooooooooooooooo no plz dont try ur gona have to change ur car so much and spend morew money then your planing to
Posted on Jan 24, 2010
where can i find an armature for a craftsman motor model RM872
Posted on May 06, 2011
How to replace circular saw bearings
If you need to ask how to replace the bearings, you probably don't have the tools or expertise to do the job. Take it to a small tool repair shop and they can do it in a jiffy.
Aug 27, 2014 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
Saw starts but jerks to a stop right away
Sounds like the bearings are wearing out. Is the blade wobbly? Does it squeal like a pig? If so, the bearings are shot. You will be able to replace the bearing on a high dollar saw. If its and off brand or homeowner type, buy a new one.
Mar 05, 2014 | Saws
Wsc255 circular saw makes a whining noise when I start it up when I put the blade onto the wood the blade stops.
Either the motor is shot or the bearings are shot. Or both. You can buy replacement parts on eReplacementparts.com. It might be worth your time to just buy a new saw. Look on eBay.
Feb 04, 2014 | Hilti Saws
How to gear spindle from housing
The unit is retained by two or three screws surrounding a retaining ring on the saw blade side, and I believe there are some screws holding the gear housing on the motor side that need to be removed as well. I just replaced the bearing on mine a week ago, and even though the situation is obvious once you figure it out I was not smart enough to do so, and wasted an hour trying to figure out how to remove that retaining ring over the bearing. Good luck
Apr 05, 2013 | Makita 5007MG Factory Reconditioned 7 14...
Saw stops when i start cutting 1/2 plywood.
If it actually binds and stops the motor...... it sounds like the motor is bad, the bearings are bad, or the blade is on backwards. If the motor keeps spinning, but the blade stops then the gears are bad or the blade bolt is not tight.
Dec 10, 2012 | Worx Versacut Mini Circular Saw
Craftsman circular saw. The blade wobbles on the shaft even though tightened down so the blade does not spin straight and steady. Without the blade I can wobble the shaft around with my fingers. Feels...
Depending on your budget, I suggest replacing the item. It sounds like your bearings are bad, which means tearing apart the case and replacing them (which don't cost much). There are two bearing encasements so you would need to replace both. If you're up for the challenge, give it a try! The bearings can typically be found on the manufacturers website.
Aug 30, 2010 | Craftsman Saws
I have a Milwaukee circular saw model 6365. It still cuts fine, but it squeals loudly (like a little girl) when running. Sorry, couldn't help myself. Seems like the motor bearing(s) need lubrication. ...
You can try to lube the bushings, but they will always start to squeal again. I have tried just about everything, 2 cycle oil works good, wd-40 is a little thin, blaster works ok for a while, reg 3m oil forget it, motor oil, no, white grease, hard to get in there, axle grease, yes, but you have to take the bushings out. The oils, you don't have to take the saw apart. Hope this helps.
Aug 18, 2010 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
Manual for #103.0205 circ. saw
Earlier comment 103.0205 Table Saws does not need lubrication is simply wrong.
The103.0202, 103.0203, 103.0305 Craftsman Companion Table Saws main Arbor axle DOES have to lubricated or else the axle bearing will quickly loosen side-to-side or vertically and fail to provide accurate saw cuts.
FWIW, Sears no longer sells Arbor Axle replacement parts... The Table Saw Arbor axle and Bearing Housing cannot use sealed bearings unless the saw case is re-milled and extensively modified. There are 2 Oil Hole Plugs (part# 475-32) that need to be opened and oil applied so the Arbor axle shaft does not get scored or worn.
I use 30wt motor oil to relube the Arbor Axle Shaft depending on amount of use, temperature, and axle rotation stiffness.
Remember, the higher the RPM speed of the table saw motor and/or the longer the use, the more frequently you may need to relube the Arbor Axle Bearing!
Nov 19, 2009 | Sears Saws
SKIL 574 7.25 CIRC SAW LUBE / OILING
The bearing are lubricated for the life of the bearings. No lub is necessary.
Sep 03, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Saws Logo
77 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
