Question about Cerwin Vega E-712 Main / Stereo Speaker
A RECEIVER COMPATIBLE WITH CERWIN VEGA E-712 SPEAKERS
WE OWN A PAIR OF CERWIN VEGA SPEAKERS E-712. WE NEED TO FIND A RECEIVER THAT WE CAN PURCHASE THAT WOULD BE COMPATIBLE
SOURCE: Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Posted on Mar 05, 2008
JULIANFIX
  • 975 Answers
SOURCE: Cerwin Vega V-35 Horns Drivers Model TMH-1
first you need a multimeter set to OHM , check on the back of the horn , remove the leads and do some reading , it should read 4 , 8 , 16 ohms depending of the brand , if you get no reading its means that need to be replaced , some horns you can detach the back (magnet w/the coil ) so you can replace it without buying the whole unit . good luck
Posted on Apr 19, 2008
tech48
  • 624 Answers
SOURCE: cerwin vega at60 and dc1515
It is called "dry-rot" and it happens with age to paper cone speakers. I am not aware of any products made to help prevent this problem. But you can always replace the woofers with new one's or find a place that "recones" speakers and that would solve your problem for a long time. If you have rubber surround on the cones, it would take much longer to have any type of dry-rot problems. The "foam" type of surround on the cones is the worst for this problem. Most new woofers have polypropelyne surround of the cones and it would probably outlast you, so replacement with a good quality woofer really is a good option.
Posted on Jul 08, 2008
budmrtn
  • 11361 Answers
SOURCE: I have a pair of
You need to check the connections on the cross over board and also Ohm out the speaker to see if the voice coil is open. If you cannot get the same woofer, then you should replace them in pair, try http://www.parts-express.com//index.cfm?
Posted on Feb 25, 2011
SOURCE: V-35 Cerwin Vega
Turbo 37: Did you ever root cause your V35's? I just ran across this post. I own a pair and have done some amateur / professional speaker building. Let me know if you still want to repair. tro
Posted on Apr 02, 2011
Do I need an amp as it only has regular speaker wire connections?
i believe you have a built in amp in receiver, so just do not push it, and its fine.
Jan 31, 2016 | Cerwin Vega Audio Players & Recorders
Where can I source a replacement tweeter for cerwin vega e-712
the exact replacement tweeter can be purchased from midwest speaker company
google it
Sep 27, 2012 | Cerwin Vega E-712 Main / Stereo Speaker
I have a pair of Cerwin Vega LS 15-series home speakers. One of the subs stopped working but still has sound coming out of the voice coil. Do i need to replace the sub?
Feb 25, 2011 | Cerwin Vega LS-15 Speaker
I am buying a pioneer vsx-d414 receiver and want to no if it will drive my cerwin vega e-712 speakersv says for receivers rated 8ohms or lower.. , just currious
Yes the Pioneer will drive the Cerwin Vega speakers. The Pioneer requires at least 8 ohm speakers and if the Cerwin Vega speakers are 8 ohms, it won't be ******* the receiver.
The speakers you have are high wattage, so the Pioneer may not be able to get the most out of them, but it should be pretty good.
It is always good to have speakers rated at a higher wattage than the receiver, that way the receiver will not fry the speakers. No matter what the wattage of a speaker, it will not pull more power out of an amplifier than the amplifier is capable of delivering. Some people have a mis-conception that if a speaker is higher rated that it will blow up the amp, this is just not true. Speakers do not pull power from an amp, they only put out as much power as the amp is pushing into them. But you can blow up an amp by driving it too hard for too long of time. They just get too hot and the heat stresses the amp circuit after a while.
I hope this helps.
Dave
Jul 18, 2008 | Audio Players & Recorders
V-35 Cerwin Vega
Jul 09, 2008 | Cerwin Vega LS-15 Speaker
Cerwin Vega E-712 Main / Stereo Speaker Logo
113 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Vito Vacirca Jr.
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
