Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
The water in the dishwasher does not drain
The water dos not drain after the rinse. do you have an idea what to do?
  • Anonymous Oct 30, 2008
    I have the same problem. The drain pump/motor seems to run but not drain. What would happen if I put some "draino" in the bottom of the dishwasher?
  • Frigidaire Master
  • 19,396 Answers
Here is a good resum of what you can do when a dishwasher does not drain.
Click on the following link : The water doesn't drain from the machine.
Posted on Oct 23, 2008
I have a ADG450 about 7 years old, the problem is there is dirty water left at the bottom of the dishwasher after finishing the cycle and the dishes look as if they have had the final rinse in the dirty...
check the pipe leading from the dishwasher to the outlet, maybe under sink. this needs to be raise up as water will flow back into washer. Had this problem myself, felt foolish when the repair man just tied it up and left. !
Jan 03, 2011 | Whirlpool ADG450 Slim-Line Built-in...
How to remove debris from the drain holes at the bottom of the dishwasher tub, which is preventing the tub from draining all of the water completely?
I had a similar problem when my dishwasher wouldn't drain and was causing the kitchen sink to back up. I poured a little drain cleaner in the bottom of the tub (where the drain holes are) and let it stand for about 15 minutes then ran a hot rinse cycle (don't put any dishes in the dishwasher while you're doing any of this). The water still hadn't all drained but after a day or two of not using the dishwasher it drained on it's own and hasn't had any problems since. I would recommend reading your manual to make sure that using drain cleaner doesn't void any warranty you may have. Also, it's a good idea to do an empty rinse cycle at least once so that there's no chemicals getting on your dishes.
Aug 23, 2010 | Dishwashers
Doesn't drain; glasses have film; rinses with used, soapy water
The white film problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Sep 02, 2009 | Dishwashers
NOT DRAINING AFTER RINSE CYCLE
Dishwasher is not filling in first cycle. only in rinse cyle then it won't drain it
Jul 31, 2009 | GE Nautilus 24" Built-in Dishwasher
Frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
Mar 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Whirlpool Dishwasher DU850DWGX1 won't completely drain
Commonly this is result of low water pressure or hose height/length
As long as the water is below the heating element and the dishes are getting clean its actually normal. Sometimes the pressure or hose length/height meets specs but will not always drain all water.
But as long as it is below the heating element this is normal
I am sure.
May 02, 2008 | Whirlpool 24 in. ADG6340iX Built-in...
Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Mar 10, 2008 | Bosch SHU9915UC Dishwasher
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
202 people viewed this question
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
