WHAT IS MATCHING WASHER TO SEDX600JQ0 - Washing Machines
Whats the capacity size for a kenmore 41743042200 washer
Kenmore 4.5 cu. ft. for the Front Load Washer
7.4 cu. ft for the matching dryer.
Jan 30, 2018 | Kenmore Washing Machines
KIRKLAND SEDX600JQ0 DRYER - NO HEAT AT ALL
No Mary, these are not the 2 fuses the manual talks about. As you said, they are breakers. The fuses would probably be inside the part of the dryer top that holds the switches and timer thingy you turn to start set the dryer. Go to link below.
http://www.searspartsdirect.com/kirkland-dryer-parts/model-SEDX600JQ0/3192/0151200/O2030137/00003.html
It talks about a thermal fuse - item 23 ($15.46) on the list and in the drawing. This fuse and #24 - Dryer operating thermostat ($20.20) are the 2 most commonly replaced parts on this dryer. If you are handy with tools you should be able to replace these.
Sep 26, 2015 | Dryers
Dryer won't stop when door opened
Possibly the switch on the door has bent far enough so that it will not disengage when the door opens. It may be stuck on the sharp edge of the metal. Look closely, dislodge if necessary. There are very sharp metal edges so be careful with your fingers. Recommend calling a "mechanically minded" friend or neighbor before calling a repairman.
Sep 03, 2014 | Whirlpool Dryers
I have an Electrolux EIFLSS55IIWO Washer. The chrome paint on the selector knob is chipping so Electrolux is sending me 2 new knobs for the washer and matching dryer. Can you please advise how to replace...
Good Morning David,
I see that you are looking to replace the selector knobs for your Electrolux washer, model# EIFLS55IIW as well as your matching dryer. This is typically not a common DIY job, and I do recommend contacting an authorized technician. However, I have found a link on the manufacturers sister website, which I have listed below, that provides a parts breakdown. It will also allow you to enter in the model number of your Electrolux dryer and locate the parts breakdown, as well as, a comprehensive listing of authorized techs in your area. Hope this proves to be helpful!
http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=EIFLS55IIW0&User=&Search=Search
-Best Regards-
WP
Apr 07, 2014 | Electrolux EIFLS55IIW - Front Load Washer...
How do you reverse the front door on a Kenmore HE4t washer?
The Kenmore HE4T washer does not have a reversible door. The matching dryer would have a reversible door.
Some newer washers do have a reversible door but it is still a very small number of washer that allow you to reverse the door.
You can not reverse the door on an HE4T washer.
Aug 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
CANNOT FIND A MATCHING MODEL NUMBER. THE MACHINE HAS #GBXR1080A0WW ,I cannot find a match
VBXR1060V0WW is the closest I've found. It's a GE washer. Parts should be the same, except the timer.
GE washer repair orange county, ca
Feb 06, 2010 | Washing Machines
Do they make a part that allows you to stack this washer to the matching dryer?
I wish they did!!! unfortunately, the kitchen is built in such a way that precludes stacking -- darn it!
Jan 11, 2010 | General Electric WBVH5200J Front Load...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Sm8525079 what is the capacity of this washer and what is the capacity of the matching dryer?
Hello.
The capacity of your washer is 3.2 cu ft and the dryer is 6.0 cu ft. This is pretty much a standard for newer top load washers and dryers. You can get bigger but it is not that much bigger.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I want to change the way my doors open on the washer and dryer
washer door can't be reversed on matching dryer best bet buy longer hoses for washer and longer vent and cord for dryer and reverse their locations
Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
