Question about Pelouze 4010 Postal Scales Equipment
How do I keep my Pelouze model 4010 on all the time
I don't want to press the on botton every time I need the scale. How do I keep it on all the time?
Pelouze 4010 display only says 4010
This is not a camera - please repost in a more appropriate forum.
Apr 17, 2017 | Cameras
How to calibrate rubbermaid 4010-88 digital scale
Pressing the ZERO button will set the display to zero.
Here is the Spec Sheet
http://www.rubbermaidcommercial.com/rcp/products/detail.jsp?rcpNum=4010-88
If you think it is no longer accurate you would have to get an engineer in to reset it. Here is the Calibration Certificate.
http://www.rubbermaidcommercial.com/rcp/ObjectServer?table=PDFs&id=660
Dec 29, 2015 | Rubbermaid Pelouze 4010-88 150 lb. Digital...
Fix my pelouze fs6 scale
Based on its appearance I'm guessing that you need to unplug it and open it up. Clean it as well as you can with a stiff brush and an electronics safe cleaner. Roaches are the most likely cause of your scales failure!
All the above may be fruitless, it may not be possible or worth the cost to repair.
Time for a new scale! You must keep it clean and turn it off and disconnect it when you aren't using it. Roaches like warm damp dirty places!
Apr 03, 2014 | Health & Beauty
I need user manual for the Pelouze Model PE5 postal scale capacity 5 lbs?
If i were you i would try to search for it on google or look on their website.
Oct 19, 2013 | Computers & Internet
When i press power botton half way works when i press full sometime work sometime don't
the switch is bad and would need replaced. MAKE note of the wiring if you attempt to do this yourself. Get back to me with the brand and model number and I will try and find you a parts source and breakdown.
Jan 24, 2012 | Drills
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
I need to download the new postal rate on the scale, but I have no user manual or connector. Please let me know how to go about doing this.
Here is the answer on the Pelouze web-site you can also download a manual here. They have all of the software you need to get the rate change installed.
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=650
May 12, 2009 | Office Equipment & Supplies
PELOUZE 4010 SCALE READOUT FAILED
my pelouse when i turn it on it stays on 0.0 when i put weight on it stays on 0.0 it then goes of i need help to get it to work
Jan 28, 2009 | Office Equipment & Supplies
Pelouze 4010 Postal Scales Equipment Logo
166 people viewed this question
Top Pelouze Office Equipment & Supplies Experts
k24674
Are you a Pelouze Office Equipment and Supply Expert? Answer questions, earn points and help others
