Question about Kenmore Ovens
How do you light the pilot on a Kenmore gas oven?
  • 3,640 Answers
We have a kenmore stove in kitchen and it has a ignitor that glows for oven. if the oven will not work check out the ignitor for oven. just remove bottom cover of oven, then you will see it. this is for electric ignitors.
Posted on Feb 10, 2012
  • 117 Answers
SOURCE: kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Posted on Feb 25, 2009
SOURCE: Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
Posted on Oct 30, 2008
mrboo747
  • 24 Answers
SOURCE: can I still light an oven even if the electric pilot doesnt work
Looks like your oven has a "glow" coil. That being the case, you will not be able to light the oven without power. It has to glow to open the valve, and there is no override for this. Sorry.
About the cord, you could install a plug on the cord, or simply replace the cord. (I realize you say you are trying to get one). Other than this, turkey on the grill is always good.
Mr Boo
Posted on Nov 20, 2008
SOURCE: gas stove the oven pilot lights but not burner
I HAVE THE SAME PROBLEM WITH MY GE GAS RANGE. THE PILOT LIGHT IS ON BUT WILL NOT IGNITE THE BURNER. WHAT IS THE PROBLEM. LINDA jolin49@yahoo.com
Posted on Jul 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: kenmore gas oven won't light. The pilot light
Put a torch on the probe. If the flame comes on them the thermocouple is weak.If nothing at all replace the safety valve.That is if you have a standing pilot. If you pilot is an electric one then it should be so bright it is hard to look at but if it is dim orange it is weak.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 07, 2009
Where is a gas fuse in a Kenmore oven?
Gas ovens don't have a fuse. Won't the oven light?
Pilot Light won't stay lit?
We get asked this question many times.
If you light your pilot light, hold in the button and then when you release it and the pilot light goes out, generally you need a new thermocouple. Gas repairs can only be undertaken by a qualified gas technician so you can't do this job yourself.
The thermocouple is a safety device that recognises that the pilot has a good flame and is enough to ignite the main burners. The thermocouple open that valve to the burner.
In limited circumstances the thermocouple doesn't need replacing, either the shield that aims the flame to the thermocouple has become dislodged, or the pilot jet is a little blocked by debris. Either way, having the appliance serviced by a qualified gas fitter is the way to go. I am sure you will have seen news stories about explosions caused by gas leaks and faulty appliances.
Posted by Andrew... on Jan 17, 2016
Jan 26, 2016 | Kenmore Ovens
How do i light my pilot on my gas oven
If it's a new model it has an electric ignition. No pilot.
Nov 19, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
I own a Kenmore Pro Series Gas Range. We just moved in and cannot locate the pilot light location
there is no pilot light.oven and stivetops have been using a electronic spark or ignitor for more than 30 years now so gas isnt wasted by burning a pilot 24/7/365
Jul 18, 2011 | Kenmore Ovens
Our Kenmore oven has stopped working. We were thinking it had something to do with the pilot light going out, since we do smell gas when we turn the oven on. Can you tell us where the pilot light might be?...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 09, 2011 | Kenmore Ovens
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Kenmore gas oven won't light. The pilot light is on but no gas. What do I do?
Sep 07, 2009 | Kenmore 30169 Electric Single Oven
Kenmore gas range model # 362.7121191 oven
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Pilot light
When you smell gas...is it all the time? If so, this is dangerous. If it only happens when you're trying to start the oven, no problem. Push the red button and hold it while lighting the pilot. Hold for 30 REAL seconds more. Release. The pilot should stay lit. If not, get a service tech.
Jun 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
206 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
