Question about Tokina 100-300 AF Lens
Tokina SZ10 5,6/100-300 - Tokina 100-300 AF Lens
Need adapter tokina 100-400 f/4.5 minolta to Canon Digital SLR
You need a Minolta to Canon adopter. Because the Tokina was made for the Minolta in the first place. Be aware that even with the adopter, there is a very great chance you always have to focus manually, because the lens can be fitted on the camera, but the electronics will not be compatible.
That is one of the things you almost aways lose, when using lenses from a different make.
Apr 06, 2014 | Tokina 100-400mm f/4.5-6.7 for Nikon
I need a new front element for a tokina 12-24mm, where can I get one from and can I do the repair myself?
Do you have a lens collimator and other equipment needed to ensure proper alignment of the element? If you don't, send the lens back to Tokina and have them replace the element.
Feb 23, 2014 | Tokina 12-24mm F4 Pro Ii Zoom Lens For...
Tokina lens problem
Try gently cleaning the contacts between the lens and the camera.
Sep 20, 2017 | Tokina 12-24mm /f4.0 for Canon
Is there an adapter for Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens to fit to panasonic gh2 m4/3?
Perhaps. Tokina makes lenses with a variety of mounts. If the lens already has an m4/3 mount then you won't need an adapter at all. Some Tokina lenses take the "universal" T-mount. In this case remove the current mount and put on an m4/3 mount. If it has some other fixed mount, m4/3 adapters are available for some of them. It all goes back to the mount already on the lens.
Jun 20, 2012 | Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens...
My 60d finding ERR 01 with my tokina 12-24mm lenses. I try to clean the contact but after a few shoot the problem remain
I have the exact same problem, it's the aperture flex cable which have a design flaw. At 12mm the flex is stretched at maximum and over the years loses its flexibility and breaks. Mine works fine from 24 to 15mm. Below 15 the camera always reports err01. All flex cables in the tokina are welded -IMHO you need to take it to a professional.
Jun 20, 2011 | Tokina 12-24mm /f4.0 for Canon
My Tokina 12-24mm /f4.0 for Canon got a little wet. When attempting to take pictures I get a ERR 01 message in my canon. Got the same error when I attached the lens to a second canon.
One of the internal circuits on the lens got more than a little wet. How long did you let it dry before putting it on the camera (which applies voltage to the possibly still wet circuit and probably shorted it out) ?. It sounds like a trip to Tokina is in order, unless you want to start a career as a repairman yourself
May 27, 2010 | Tokina 12-24mm /f4.0 for Canon
I have the tokina atx 280 pro lens but no hood, where can i get a replacement hood? or other brands that can fit in my lens. thanks
Most good camera shops and even some online camera stores should be able to help you
Part# BH775
also look here and contact this site as as long as it fits the lens size you have a variety of shapes.
http://www.jsteven.net/tokina-lens-hood/
you can make your own see this page
http://www.lenshoods.net/hoods/Digital-Lenshood-Tokina-AT-X-280-Pro-AF-28-80mm-f-2.8.php
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Tokina AF 28-80mm f/2.8 AT-X Aspheric Pro...
Over exposure in cold weather
I suggest that you contact Tokina directly to find out what range of temperatures your lens is designed to work across.
Your expression "cold weather" is an imprecise term; where I am in the UK means at worst down to a few degrees below freezing and usually a bit above, but when I'm in Moscow they don't consider it to be cold until the temperature drops to around minus twenty-five Celsius.
Depending on where you are, your lens may simply be unable to cope with what you describe as cold weather but you won't know until you have the specifications from Tokina. If it turns out that your lens is not performing as intended, then the manufacturer will be able to suggest remedies to you.
Sorry I cannot be more specific but Tokina do not appear to have published the range of operating temperatures in the public domain.
Mar 01, 2010 | Tokina 12-24mm f/4 Pro DX for Nikon
Tokina 35-300mm af zoom lens
Unless you have extensive experience, this is best left to professionals. If you didn't spend much, then you could "learn" on it, but if it is something you really value...don't do it.
Oct 29, 2007 | Tokina 35-300MM F4.5-6.7P KAF Lens
Cameras Logo
83 people viewed this question
Top Tokina Cameras Experts
Are you a Tokina Camera Expert? Answer questions, earn points and help others
