Put the card into a card reader attached to a computer. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files.
You can then format the card in the camera and, if you must, you can use the card reader to copy the pictures from the computer to the card.
SOURCE: sd card will not format
Try formatting the SD on your computer. You will need a SD card reader.
Go to 'My Computer', right click on the card icon and select Format.
The rest is easy!
SOURCE: Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
SOURCE: My Z740 won't format my memory card. When I turn
My Z740 won't format my memory card. When I turn it on - it says memory card needs formatted. I tell it to format - and it just repeats the Memory Card requires formatting message.
