Question about SanDisk Sansa Clip MP3 Player
How to remove radio tuner from sansa clip? - SanDisk Sansa Clip MP3 Player
4 Suggested Answers
jazzyboy11
  • 728 Answers
SOURCE: I have a 4 gb Sansa Clip. How do I switch back
You can go to the main menu on your player and select which one you want to use at a time. Here is a manual that describes everything you need: http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Page 6-7 has the menu options/controls that you can use to do that.
Posted on Oct 31, 2009
SOURCE: FM radio on Sansa Clip does not work
Have you muted the radio by mistake.If you have there will be a square symbol under the FM sign.Press the top of the ring.
Posted on Jun 07, 2010
SOURCE: how do i remove the
You can download the clip+ firmware and replace the "a" with a "g". basically you will rename the firmware file to "clppg.bin" once you upgrade the firmware select English as the language and rest of world as region and the fm radio menu selection will be removed.
Sansa Clip Firmware upgrade ..here ..
See the following list of suffix letter codes and effects ..here
Posted on Feb 07, 2011
I need help disabling my fm radio on my new sansa clip.
This is possible. It requires firmware upgrade to disable the FM radio. Follow the directions below link:
http://kb.sandisk.com/app/answers/detail/a_id/5224/~/removing-the-fm-radio-feature-from-the-sansa-clip%2Fclip%2B%2Ffuze-player
Good luck.
Jun 19, 2011 | SanDisk Sansa Clip MP3 Player
How can I remove SlotRadio advertisement from my Sandisk Sansa Clip + 8Gb. I can't find any SlotRadio files in both UMS and MTP modes.
You will need to manually reinstall the firmware from the Sansa Website
Current version is 01.02.15 (at this date 1/30/11)
On your clip the version number may be followed with an "a"
Your clip should be at least 50% charged or greater before following these steps
DO NOT use the Sansa Updater
1. Download the current firmware for your Clip+ from the Sansa Website
2. Save the zipped firmware (clipplus01.02.15.zip) to a folder you can easily locate (Downloads)
3. Create a new folder naming it what you wish.. (Sansa Firmware)
4. Open the downloaded zipped file(clipplus01.02.15.zip) using something like Winrar
5. Delete the file clpp_data.dat (This is the slot radio ad)
6. Extract/unzip the remaining file clppa.bin to the new folder (Sansa Firmware)
7. Plug in your Sansa Clip
8. Drag and drop (copy) the clppa.bin file into the internal memory or root of the clip
9. Unplug the clip from the USB port on your PC
10. The firmware will update and the media will refresh.. and you will no longer have the Slot radio Ad on your clip
Good luck
I have three clips.. 2 of the 2 gb.. 1 of the 4 gb and now a plus 8 gb.. and yes..I too found the banner ad annoying as all get out.
Washoe
Jan 18, 2011 | SanDisk Sansa Clip MP3 Player
Jun 04, 2010 | SanDisk Sansa Clip MP3 Player
How do I record FM radio programs and transfer them to my computer?
unfortunately, the voice recorder works only as voice recorder, it cannot play FM and record it at the same time. though you can play fm radio from another device and record it using your SanDisk mp3 player.
To transfer your recordings from your mp3 player, connect your device to your PC.
Open "My computer" from your PC and you'll there "your Sansa Player"
Double-click on "your Sansa Player", then open the "Music" folder, then, open "Recordings" folder.
You'll find all your recordings on that folder.
May 14, 2010 | SanDisk Sansa Clip MP3 Player
Fm tuner works but the screen is blank. brand new, just got it today...
You should update your device with new firmware at http://forums.sandisk.com/sansa/
Depend on your device Clip or Clip+.
Good Luck
Jan 27, 2010 | SanDisk Sansa Clip MP3 Player
No sound from radio on sansa clip. mp3 playing still works fine.
Did you accidently pause radio. put sansa in radio mode and push the play/pause button.
Jan 22, 2010 | SanDisk Sansa Clip MP3 Player
SANSA
My computer not recognise sansaclip
Jun 24, 2008 | SanDisk Sansa Clip MP3 Player
Sansa 2.0
 i would say no but it depends on what you mean. if you want like xm or am radio, then no, because there is only an fm tuner built into the player. i guess i would need you to specify what you mean by radio programs
Apr 17, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Pioneer Super Tuner 3 Removal
If it's been installed with the original DIN mount, there are 2 small flat clips that slide in a small slot on each side of the radio. The 2 pieces of metal are pushed in to release the clips holding the radio in the bracket. Then the radio pulls out
Those clips come with the Pioneer stereo but should be available from a place that sells/installs car audio
Oct 16, 2007 | Pioneer DEH-P690UB CD Player
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
