Question about Samsung Galaxy GT-S5570
My cell is not getting charged.. battery chrging sign doesnt ***..2 hours b4 when i plugged in ti charge it was alright.
Sometimes if its not completely drained when u charge it u risk the chance of ruining your battery...but you can try leaving your battery out for a while and then put it back in...if that doesnt work you might need new battery or perhaps a new cord.
Posted on Feb 10, 2012
  • huda_gulzar Feb 10, 2012
    thnx ill try it.. hope it works .
    Still the same.. I cant figure out the problem is in my charger or mobile..
Y bhanchod samsung wale gandu hai chutiya banate hai shale humko bhi or phone bhi . ghatiya device innovate karte hai shale m********
Posted on May 23, 2013
Phone is plugged in to charge, but no power seems to be getting to the phone from the charger. I have tried various plug sockets and there is no power cut. the phone has not been near water. Does the...
if itz under worranty better return back
yu may get a new1
problem is wid chrging point or charging ic
better contact customer care or service centre nearby
Jul 30, 2013 | Android Galaxy Ace
Rc helicopter battery
Tip #1: Wait at least 15-20 minutes after you drain a battery to charge it.
This allows the battery to cool down before each charge cycle. I would make sure the battery is cool to the touch before charging it again, but 15 minutes should be alright.
Pointer #1: If the battery is hot after use, then it is a good sign that your battery is getting old.
Anything warmer than about 140 degrees is dangerous; if your battery is this warm after flying, it's time to replace it. I wouldn't use it anymore so it doesn't explode. This is a good indication that in the near future you should look to getting a new one. I would recommend a higher quality / mAh battery (keep the same voltage, though) if the battery running out is a stock battery.
Tip # 2: Wait at least 15 minutes after charging a battery to use it.
Once again, this is to let the battery's chemical processes have a break.
Pointer #2: Battery terms to understand when buying a RC battery.
mAh: Milli Ampere Hour. This is basically the electric charge transferred by a current of one milliampere for one hour. I'm no electrical genius, but the higher the mAh, the longer a battery will last per charge. This is the one part of a battery that you can change without damaging the heli.
Volt: The electrical pressure. Basically this determines how much power can flow to the motor. For lipo batteries the voltage comes in multiples of 3.7 volts, or 3.7 volts per cell.
Cell: An independent 3.7 volt battery.
If you would like a little more in-depth explanation, I found this howstuffworks article helpful.
Litium-Ion (Li-Ion): a type of battery that has a rigid cell structure and shape. It is safer than a lipo battery, but not as efficient.
Lithium-Polymer (Lipo): a type of battery with a flexible cell structure and shape. Lipos can catch fire and explode if mistreated or dropped on a hard surface. BE CAREFUL! Although more dangerous, they are more efficient than li-ion batteries and can come in practically any shape with the same cell count.
Look below to see how the li-ion (on the right) has two defined cylindrical shapes in the package, whereas the lipo to the left is just a rectangle with no visible curvature or cells.
Jul 19, 2013 | Cell Phones
My Samsung Galaxy Note 10.1 battery not charging can you please tell me why
Same problem on my Samsung Galaxy Note 10.1 (GT-N8013) w/ OS 4.1.2
It just boots up and shuts down.
Dec 06, 2012 | Samsung Metallic Gray Galaxy Note 10.1in...
How do i get my samsung instinct to turn on it hasnt turned on in 2 days
The power on button is on the end call button, hold it down for some seconds, lets say about 15 seconds.
First ensure that the battery, the charger and the phone is intact by carrying out some tests on them to be able to detect where the problem is from.
Test the battery, by inserting it in another phone and charging it for about 2 hours then you power it on, to see if it will power on the other phone. If it works, then it means the battery is alright and if it does not power on the phone, then you know the battery is bad and need to be replaced.
Test the charger by trying it out on another phone to see if it will charge the phone, if it charges, then it means the charger is alright and has been charging the phone all this while, but if it does not charge, then it means the charger has not been charging the battery all these while but there is a problem somewhere.
Finally, you need to test the phone by inserting a well tested battery in it, then you try to charge it with a well tested battery then power it on to see if it will turn on. If it does not power on, then it means there is a problem somewhere on the phone. Most likely its power panel is bad.
Hope this information helped you.
Jan 08, 2011 | Samsung Instinct Cell Phone
Doesnt Charge
Replace the battery, inspect the charging port for debris and clean if necessary. Charge the new battery, first inspect the wire on the charger, look for any pinches or defect. Check that the adapter that it is producing electricity. If this doesn't correct it you just might consider purchasing a new phone or better yet get a FREE phone from this company, they have excellent customer service and offer all of the major carriers! I recommend getting insurance on your new phone. Anyway best wishes!
http://shop.acnwireless.com/mobile/?r=acn&eid=01958203
Aug 31, 2009 | T-Mobile Sidekick® 3 Cellular Phone
The charger port on my lg voyager is frayed. If i buy anew charger port, is it easy to install? i thought it was my battery, so i bought a new one on Amazon. put the battery in and it worked fine. i have...
you have done well in troubleshooting it. if you have tried another charger on it and its not charging, then you have to replace the charging port. if you are good opening phones, then replacing the charging port will not be a problem. the chrging port is usually not screwed, it is just fixed to the board by contacts. look for the replacement part and change it. other wise, take it to a phone technician with the new charging port and replace it. good luck!
May 27, 2009 | LG VOYAGER VX10000 Cellular Phone
Phone wont turn on
well frist put the charger in and let it charge till sy chrging for about 3 hours then then it will say don charging and then take the cord out and then turn it on
Aug 14, 2008 | Motorola Mobility TracFone C139-4 Cellular...
Battery not charging / te charging unit/is alright
attach the USB cable that (may have) came/come with the unit. PLug into computer and get check for updates and then leave it plugged into turned on computer for 6-8 hours. Do this routinely every two months
Jul 14, 2008 | GPS
Sidekcik Lx will not charge.
alright..my sidekick does he same thing but i fund a temp fix....the guy at the store says its the charging port..idk.....first plug it in....let it charge 4 ten min....then try to put in on...it will say the low battery sign...dont worry...then t8 sumting pointy and push it in the little reset hole behind the screen as you swivel it...as soon as you see the little box with the circles in it you press and hold the space button... hopeully it will start by showing the four butttons....if it does start and cuts off at the tmoblie sign jus let it charge longer and do it agian....hopefully it will work on yours it worked on mine....gud luk
Jul 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
I hav a phone problem and a samsung 1gb mp3 player
both of your device have some hardware problem send it to service center for details checking.
Jun 20, 2008 | Nokia 6600
Samsung Galaxy GT-S5570 Logo
208 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
