Question about Olevia Televison & Video
Sound cuts of Olevia 265FHD T11
You have sound when you turn the TV on. After a little time (never the same amount of time) the sound will cut off. You can turn off the TV and then turn it back on and the sound will be back on only to cut off again.
SOURCE: no picture but has sound
we had the same problem and took it to be repaired and they said it was just a,loose connection
Posted on May 31, 2008
your bulb has burnt out
Posted on Sep 09, 2008
hey i think i know your solution on how to fix that you should get another tv lol jp go to my web site and I'll tell you a couple of methods to try.its meatspin.com
Posted on Feb 28, 2009
  • 45 Answers
SOURCE: Need a Manual for the Olevia 237 T11 37 TV Manual
http://olevia.com/ecms.ashx/de6cad9b-c9dd-41cd-9462-2b87834ff107/Products/237T_English_User_Manual.pdf
they also have a booklet for sale
contact this number 866-965-3842
Posted on Jul 29, 2009
budmrtn
  • 11361 Answers
SOURCE: 226-T11 Olevia ... screen is black... sound works
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 16, 2009
Just bought a LG home theater system for my TV, my model number is 247FHD-T11, the theater system uses and hdmi cable, but my tv has not connect, what am I doing wrong?
It appears that television does not use HDMI to connect audio, only video. Sound is via twin phono leads. Here is the page in your manual.
Olevia 242T FHD User Manual Connecting To Home Theater System Or Earphone...
Table of Contents
Olevia 242T FHD User Manual Table Of Contents
Setting up the Sound Quality. Look in the settings to see if an Firmware update _may_ have included HDMI audio output.
Olevia 242T FHD User Manual Audio Osd Adjusting Sound Quality Description...
Apr 19, 2017 | LG Audio Players & Recorders
My olevia 237-t11 turns off by its self and sometimes makes a loud screcheen noise
Sounds like either the main or display power supply is failing. Might consider a new TV. Parts could be found but it might be hard to find them.
Aug 28, 2014 | Olevia 237T 37 in. LCD TV
"Olevia 65 LCD TV"
8e12bdd8-2e36-4e3d-b2c6-b240db1b35af.jpg I have found a solution to the scrambled / freezing picture for the 65" Olevia LCD T11. At the recommendation of 3D electronics in plano TX, I installed a 200mm fan on the back cover with the air blowing directly on the CPU of the main / video card. I had to cut a whole in the back cover to mount the fan and actually left the bottom panel off to let more air flow. There are some spare 12v terminals on the second power board on board furthest from the main board. I cut the whole out with a jigsaw and had to extend the power wire due to the length required.
Jan 07, 2013 | Olevia Televison & Video
My OLevia 265FHD-T11 powers on shows the Olevia logo then goes black what is the problem
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 24, 2012 | Televison & Video
I have a blank screen. i have sound but no picture. moed 265fhd-t11
Good day,
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this will helpout
Sep 12, 2011 | Olevia Televison & Video
I have a olevia 42 inch 242FHD-T11 it is around 3yrs old and now it will not turn on with the remote so when I turn it on manually it comes on but with no sound after I do this 3 or 4 times the sound...
I am also having this exact same problem... except sometimes the power wont even come on with the power button on the tv. did you figure out what it was?
Thanks
Sep 21, 2010 | Olevia 252T LCD TV
My 42 inch olevia 242fhd-t11 tv just shut off and will not come back on.. The blue led light will not come on either... Also was having intermittent sound issues for the last couple of days prior to it not...
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Jun 12, 2010 | Olevia LT42HVi 42 in. LCD Television
Televison & Video Logo
157 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
