Question about Frigidaire PLMV168 Microwave Oven
Shuts off, must reset clock
The popcorn button has never worked, when you press the popcorn button, the display freaks out and the clock must be reset. However in the last couple of days, while cooking and after a few seconds to a minute, the microwave stops and the display reads "please set clock". Can the two problems be related? Please help! Jack
  • 2 more comments
  • Jack Roberts Sep 08, 2006
    Furthur info on micro shutting off.
    Could moisture be getting onto control panel? Problem realized again when food prepared on the cook top was in the process of being steamed and or boiled.
    Jack
  • Anonymous Nov 30, 2007
    Mine has the exact same problem. Has someone found the actual solution?
  • Need Help 7 Jan 17, 2008
    Same problem. A couple seconds into cooking - the microwave will stop and request that I reset the clock (as if the power was turned off.) However, it is does not happen everytime I use the it.
  • Anonymous Mar 30, 2014
    we lost power. I reset the clock and after about 5 seconds the display blinks "Timer" and "Time" but no buttons work. I disconnected power a couple of times and the same thing keeps happening
I had this problem also, but what happened with mine is that it popped about 1/2 the bag and then the light popped inside the microwave and it shut down completely. My husband went out to see if the circuit breaker popped, it didn't, but he switched it anyway and the microwave came back on. So he put the micro on a power surge protector, and we tried again, but this time we used the minute timer and it just popped about 1/2 the bag and then blew. The surge protector still was working and so was the outlet, but the microwave was blown. About a 1/2 hour later, I looked in to see the micro and the clock had come back on. We just purchased this at Home Depot this past weekend, should we take it back and get another one? or is it our electical outlet?
Posted on Mar 12, 2007
  • Frigidaire Master
  • 9,098 Answers
This does sound like a loose power connection. It is likely on the control board. Feel free to e-mail me privately if you'd like to have it repaired or if you have other questions.
Posted on Sep 15, 2006
  • William Miller
    William Miller Nov 11, 2006
    In my professional opinion, I truly believe it is a bad connection on the control board.
    When you use the POPCORN button, you are doing sensor cooking.
    That sensor consumes a good bit of power, and that would explain why the failure is more likely to occur during sensor cooking.
    The oven is acting just as it would if you unplgged it!
    We regularly repair these control boards nationwide for $32.50.
    You can do a Yahoo search on Yahoo.com for:
    microwave circuit repair
Jack, I just started having the same problem with my GE Spacemaker microwave a week ago. I've had it for only 16 months, and it was manufactured in January 2005. It shuts off after a few seconds of heating and then you have to reset the clock and date. And then it does it again. I did some research on the web...searching GE JVM1650 problems...and found some unfortunate information from Epinions.com. Other people are having the same problem and it may be an "non-repairable problem." I wrote GE an email a week ago through their customer service and have not received a response. (I also want to mention, in Epinions, there was someone who wrote that their GE microwave wouldn't heat up, and it turned out to be the magnetron.) Elaine
    Scholar:
  • 72 Answers
Sounds like you could have a fauly control circuit. Something like when you press the pad the processor does not interpret the information correctly and resets itself. Or the power going to this circuit is being interupted. It is VERY dangerous to work inside of a microwave. So you could get an estimate from a repair shop. But those control boards are expensive. Do not attempt to repair this yourself. For your own safety.
Posted on Aug 07, 2006
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: timer will run, but won't cook
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Oven Does Not Start Cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 25, 2008
wiznet2000
  • 86 Answers
SOURCE: Microwave just stopped cooking!
The simplies is the fuse, which is located inside the unit, you need a screwdriver to open it
Posted on Aug 18, 2009
Troubleshooting Ge Microwave that is acting bizarrely
Sounds like the main control board, but further testing should be done to rule out other possible causes. One thing I would do is to check to make sure it is plugged into a grounded outlet that is actually grounded. Bizarre behavior can be caused on some ovens because of a lack of a ground connection.
Oct 13, 2016 | GE Microwave Ovens
Our 2006 Samsung Microwave has suddenly ceased to heat anything. The clock works and the turn table goes around, but that's it. We had a couple of power outages just before this happened. Could it be...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Nov 29, 2010 | Samsung Microwave Ovens
''Press Clock'' but can't press buttons, then beeps with F4 error
F4
Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor
Sep 07, 2009 | GE Microwave Ovens
Popcorn Castastrophy !!!
You would have to remove the top cover and check to see if the main fuse is blown. Usually a 20 amp slo-blow. There are thermal cut out devices, they will reset when the unit cools, so plug it in the next day and see if the clock and power is back up. good luck, Dale
Aug 06, 2009 | Magic Chef Microwave Ovens
When I place food in the Microwave and press the express button or any other button like popcorn it will run for approximately 5 seconds and then the display will start going dim or flicker. After that...
if you are using an extention cord pls refrain from doing so, kindly plug this to a wall outlet,
or this is an electrical problem, there is insufficient current to drive a high wattage appliance, thats why it seems the unit is resetting
or there is a problem with the control board it self
Aug 06, 2008 | Microwave Ovens
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Sharp Carousel Microwave R-320FQ Serial # 26805 Mfg. Dec. 2002
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
It may have an intermittently shorting keypad or another problem on the control panel, which we repair for customers nationwide with our guaranteed $39.95 service.
Jun 08, 2008 | Sharp R-1480 Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stops with message that does not work
You probably have a bad connection on the cirucit board and/or an intermittent door switch. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
May 05, 2007 | GE JVM2070 Microwave Oven
Frigidaire PLMV168 Microwave Oven Logo
580 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
