Question about Whirlpool Duet GHW9150P Front Load Washer
My Door Won't Unlock
I cannot get my washer door to unlock! I have tried the cancell botton and I have tried just unplogging it to see if that would reset it, but nothing seems to work...Does anyone know what else to do to get it unlocked??
  • Anonymous Oct 23, 2008
    I had the same problem, the water had dripped into the tub and i had to hit the drain button. It went through a cycle and the door opened. Good luck
    Scholar:
  • 112 Answers
There is a manual release rope that hangs down the front length of the unit. Usually by removing the lower access panel you can reach up and tug it to open the door. Then you will have to check the wiring and solenoid to determine why it doesn't open when it is supposed to.
Posted on Oct 23, 2008
My washer started and now it stopped and it won't cancel/unlock and the door will not unlock. I have tried to unplug and replug and it still will not start or unlock the door. My clothes have been...
the most typical reson the door wont unlock when cycle is finished is because not all the water drained properly due to a blockage in the filter for the drain pump. This tip i wrote explains how to take apart the washer and clean the filter on the pump.
http://www.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
If you find the filter on the pump to be clear the door lock asm. will need to be replaced.
GENE
Sep 04, 2011 | Kenmore HE2 Plus Front Load Washer
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
UNPLUG THE MACHINE
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door locked.... tried to unplug and cancel button - still not open??
Try holding end cycle button for 30 seconds if no. Then try reset process Press "Pause/Cancel" two times to cancel the cycle. Press "Drain/Spin" if there is water in the tub. Unplug the or disconnect power for two minutes, then plug the washer back in or reconnect power.If no then here is the manual open process. Unplug the power cord of the washer from the outlet. Locate the toe panel. This is the section of metal at the bottom of the front of the washer, directly below the door. Remove the three screws on the bottom flange of the toe panel, which connect it to the washer. Lift the panel slightly and pull it forward to remove. Manually unlock door Reach up inside the front panel and locate the door latch assembly on the right side of door.Feel for a tear-drop shaped tab on the bottom of the door latch assembly. This tab will manually unlock the door.Gently pull down on tab about 1/4 inch or until you hear a click. The door should open.
Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I want to unlock my door
Manually Unlocking the Door Lock System
1. Unplug washer or disconnect power. 2. Remove the lower kick panel. 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab. 5. Gently pull the tab down about a ¼" or until a click is heard. 6. The door may be opened.
Apr 12, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light will not go off.
Do you have any error codes?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
