Question about Sony Playstation 3 (PS3) Console
Dots??? when ever i play certain games, or even boot up my PS3 with the original theme my screen has a bunch of black dots or sometimes just dots/ and screen glitches...its really annoying and makes my PS3 experience ****...I have a 1080p TV and a optimum HDMI Cable since buying the PS3 I tried it on 2 1080p TVs with the same result...HELP
  • d3lbto Oct 23, 2008
    i have screen glitches then the ps3 hangs and i cant do anything. i can hear the controller moving up and down but nothing can be seen.
    Problem Solver:
  • 9 Answers
Call the sony support or try to update the firmware version. or plug every other pheriphial and try just with one cotrolleer, good luck
Posted on Oct 23, 2008
Insignia 26" HDTV 1080p, I just bought it the
First off what type of input are you using going from the ps3 to the tv. If your using HDMI try changing the different video settings. Black ops actually has a lot of problems right now on ps3. So I wouldn't use that as the basis of what is working or not, I would try other games to see if it's working. Adjust the video settings on the ps3 and see if that helps. If that doesn't try using component cables and see what that does for you.
Thank you,
Lee
Feb 01, 2011 | Insignia 42" LCD Flat-Panel HDTV
What arethe black dots appear when playing a xbox game
These "black dots" you talk abotu could be a variety of things and since you haven't given much detail it's hard for me to say.
Just double check it's not your TV or cables or any nearby electrical products causing interferance so you're certain the problem originates from your Xbox 360.
Hopefully, it's just a problem with your cable, maybe it's not plugged in right or maybe a replacement will fix it.
When I say hopefully, I mean, hopefully it's a cable fault as opposed to an Xbox 360 hardware fault. Variations of black lines or dots, or just general artifacts on screen while using your 360 usually happens prior to a hardware fault usualy concerning the GPU.
I guess it's just a waiting game for you now mate.
Just check it's not your TV or cables or any nearby electrical products causing interferance.
Nov 15, 2009 | Microsoft Xbox 360 Console
Black screen with dots but everything is fine.
this is your TV Set. it needs to be bigger and more HD than the one your using.
Sep 06, 2009 | Microsoft Xbox 360 Console
When PS3 boots the screen turns green with white dots
Emergency cooling should be cleaned. If not cleaned, you risk expensive repair.
Oct 24, 2017 | Sony Playstation 3 (PS3) Console
Screen fills with black lines and dots when playing games
Does it ever get the Red Ring of Death? If not, it sounds like it will soon. I have lost 2 360s that way.
May 11, 2009 | Microsoft Xbox 360 Console
Black lines 1/8 of an inch apart going down my screen when playin
I had this happen a few times, then after a while it stoped working all together. In the end I was getting the E74 message code appear when I turned on my xbox 360.
You'll probley get this happen with yours soon, the E74 code means theres a problem with your visual display.
Sometimes it can be as simple as changing your HD Lead or scart lead, whatever your using. If you know someone else with a xbox try theirs.
If this doesn't work you'll have to send it off to mircosoft, it will be free if your still under warrenty, if not I think it's about £100+
Or you could go on www.cd24-7.co.uk and buy one of their DIY kits.
Hope this helps.
Jan 11, 2009 | Microsoft Xbox 360 Console
Gaming screen
buy a disc cleaner and only use once it will work and only cost 5-10 pounds.
Oct 07, 2008 | Microsoft Xbox 360 Console
Black dots during gameplay only on 360
I had this problem with my very first Xbox 360. It started showing little white dots instead of black though. I just dealt with it for a while, and it finally got to the point where it would fill up the screen fully, to where I could only see my gun in Halo 3 and that was about it. I was forced to call Microsoft and have them fix it.
Mar 10, 2008 | Microsoft Xbox 360 Console
Another stange graphic problem
This may be an indication of the graphics processor overheating. When the card overheats it tends to leave artifacts like black dots. Newer games typically put harder stresses on consoles than older titles. This would also explain why the dots aren't showing up in menus, menus don't require as much juice as game play. I would blow out the system with some canned air and try playing the system in a cool, well ventilated area to see if that helps. Sometimes this can be a permanent issue with the graphics processor and you would need to send it in to Microsoft.
Aug 22, 2007 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
215 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
