Question about Samsung DLP HL-P5663W 56" TV
How to change lamp in samsung dlp 56
Is it easy to change the lamp my dlp? my screen seems to be getting darker by the minute and i can harldy see the picture anymore! never thought i would have to squint at a 56" screen....lol
  • Samsung Master
  • 6,694 Answers
Check the following videos to find out how to replace the lamp (BP96-00826A) of DLP HL P5663W.
http://www.dataentryjobs.us/70091.html
Ajin
Posted on Feb 10, 2012
5 Suggested Answers
SOURCE: Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Posted on Aug 31, 2009
  • 72 Answers
SOURCE: During darker programs the picture is very dark.
need a new lamp
Posted on Jun 11, 2009
SOURCE: My 56 inch Samsung DLP keeps shutting off. I have
Once before I had this same problem and FixYa gave me the solution. When you replace the lamp door, there is a switch inside so be sure the door is put in at an angle so to hold the switch up. It solved my problem after numerous repairmen missed it.
Posted on Sep 05, 2009
  • 1015 Answers
SOURCE: Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Posted on Jan 12, 2010
Testimonial: "Thank you for your help. After replacing the colorwheel, the tv came right up.!!!!!"
Samsung DLP has gone darker
The 60 K hours is bogus---Average life on a OEM lamp is 2,000 hours or two years average---if you got four or more years you were lucky.
To your problem---
Jun 13, 2012 | Samsung Hl-s5687w 56-inch 1080p Dlp Hdtv
Samsung dlp has dark picture?
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours witch is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen here is a link with the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=BP96-00608A
Sep 03, 2010 | Samsung DLP HL-P5663W 56" TV
I have a Samsung 42" DLP. During the daytime I can hardly see the people and definition on the screen. It is all very dark. Nightime is better.
check your video settings there are 3 or 4 usually that all have various levels of brightness, it may be set to one of thelower ones. or you can go into tv menu and try kicking up the brightness. if no luck the lamp may be failing if not recently replaced they begin to make screen darker before they fail.
Jan 23, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung HL-S5687W dlp tv, the picture is darker than usual and getting darker by the day
Hi
Well for what you describe it sounds like the symptoms of a worn out lamp giving you the last kicks,basically the the lamps are design to go for 6,000 to 8,000 lamp hours if they're Phillips and a generic lamp could give you 3500 to 4500 lamp hours so with this in mind you could search for a new lamp at Discount-merchant.com or you can go to Ebay also you can go to www.fixyourdlp.com for more troubelshooting
Please rate this if it was helpful.as I do this for free.
Regards
Jan 05, 2010 | Samsung HL-S5687W 56" HDTV
I jest replaced the bulb of my Samsung Projection TV about a week ago and today it blew again. What is wrong? I am thinking of using it for target practice.
easy. take out lamp. put it in freezer for 5 minutes. reinstall. when unit comes on, go in menu to lamp setting. reset lamp setting to zero hours. the tv still thinks it has old lamp. easy
Nov 13, 2009 | Samsung DLP HL-P5663W 56" TV
Our Samsung Model HLP5063WX/XAA - dark images
I suspect that you may need to replace the ballast for the lamp and the power supply board.
Oct 30, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP 72inch, recurring loud pop then fuzz for 3 seconds
I pulled out the Lamp, cleared the dust inside with one of those air blowers and returned the Lamp. That seems to have fixed the picture problems I was having.
Jul 07, 2009 | Samsung DLP HL-P5663W 56" TV
Black screen with a Blinking lamp in the front
Hi..if your lamp is on but no picture, then your lamp is good. Your problem is the DMD board (digital mirror display board) is bad. This is very common with Samsung DLP.
Mar 27, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung DLP HL-R-5667W lamp LED comes on solid, no picture, then turns off
DO you have the owners mannel if so read it and see what they would do ,have you removed the lamp and if so how did it look? some lamps only last for 5,000 hrs and others 8,000 hrs If lamp is bad TV will not come on.
Feb 20, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
89 people viewed this question
Jerry Greenberg
Jerry Greenberg
