Question about HP Pavilion dv6000z Notebook
What can i do if my screen breaks into four? - HP Pavilion dv6000z Notebook
  • 807 Answers
Get it fixed with a new screen.
Posted on Feb 10, 2012
All four windows stopped working at once
One of two things. First the master switch on the driver side died (unlikely) next, you lost power or ground to the switch. Wires break. Open the drivers door. Look to the front, you will see a rubber boot going from the car to the door. This is usually where the wires break. Just a note. When they break here, I solder a wire to the car side and run it into the door side, cut it in to the appropriate wire. trying to fix them in the jam is a real pain and doesn't last long.
Dec 25, 2014 | 2006 Mercedes-Benz E-Class
The bottom four app buttons don't work. It wont recognize my touch. Can't bring up phone, contacts or any other
If it's still under warranty it'll need to go in for repair. That's a symptom of a digitizer failure. (The part of the screen that recognizes touch). If it's out of warranty the replacement part can be bought off eBay for anywhere from $20-$60, depending on the specific model number and how technically proficient you are. It's really easy to break these screens trying to remove them so it might be better in the long run to just buy a replacement.
Mar 31, 2014 | Boost Mobile ZTE Warp Sequent Touchscreen...
Lenovo R52 think pad makes 4 beeps after computer has been on awhile. Once it starts beeping there is a small break and then it beeps again 4X.
Four cycles of four short beepsand a blank screen.Problem:----> System board (security chip)
Do you still have warranty?
Try pulling out memory sticks and putting them back in.. here is something I found. Might help.
For reseating instructions (for my T42p), I used:
http://www-307.ibm.com/pc/support/site.wss/MIGR-46513.html
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-46515
and a video, which reminded me that there was one more screw to remove(!):
http://www-307.ibm.com/pc/support/site.wss/MIGR-50227.html
Dec 03, 2012 | Lenovo ThinkPad R52 PC Notebook
Replace display
remove the panel just below the lcd there you will see two screw remove them and there will be two connectors to the motherboard remove them then lift the LCD upward this will remove lock from the laptop next remove the four screw in the side of the LCD screen the plastic casing contains lock be careful while releasing the lock not to break the cover after removing the cover remove the screen just by lifting you will see a small PCB in the bottom of the LCD remove the connectors then replace the new display and do vice verse
Oct 27, 2011 | Computers & Internet
I was driving my Sante FE yesterday and stopped at a red light. When I released the break all four brakes where still grabbing. As I was close to home, I kept it in 1st gear and drove back home. At that...
you are right when you mastercylinder related,as you have a very small port (compesating)inside the cylinder and should a small partical enter and block this port the brakefluid cannot push back when releasing the brakes causing the brakes to bind.the cylinder should be removed and cleaned.
Jul 11, 2009 | Hyundai Santa Fe Cars & Trucks
I need to change the master cylinder in my fj62 landcruiser and I am not sure how to do it. Looking for help please.
If you want to change break master cylinder,first remove two break pipes then remove four nuts which is holding master cylinder to breake booster.careful breake fluid from the car body and your self.
put the new breake master cylinder tight four nuts, before you fit the braeke pipes get some body who can hold breake bedel down put the breake fluide tell him to pump breake bedel when the brake master take fluid hold your fingers where you want to fit brake pipes when you feel more pressure which is pushing your finger tell him to hold the bedel down while you tighting the pipes.
you dont need to bleade the wheels. it is ready.
the ather thing when you remove the breake master put the new one then fit the brake pipes fil with the breake fluide then bump so you must bleade all wheels
Jun 16, 2009 | 1998 Toyota Land Cruiser
Black screen
If the screen is breaking up into multiple screens, the video resolution isn't set correctly. Change the video properties back to the native resolution.
Right-click on an empty area of your desktop screen. Click on Properties at the bottom. Now click on the Settings tab.
The Screen Resolution slider should be all the way to the right, close to -> More.
The Colors should be set to the highest setting.
When you close the lid, you may have your laptop set to Sleep Mode, check that. You may also have your screen saver set to Blank, and no screen saver has been chosen.
(1.Screen Saver: Right-click on empty area of desktop>Properties>Screen Saver.
2.Sleep Mode: Start>Control Panel>Performance and Maintenance>Power Options>Power Buttons>When I press the sleep button on my computer>Then choose what you want it to do)
If none of this helps, I suggest you have a problem that HP needs to repair. Since you bought this dv9700t last July, would I be correct in assuming it's still under warranty?
Jun 02, 2009 | HP Pavilion dv9700t Notebook PC
Glass screen is breaking away from body of tv
Please return it ASAP. This is not normal.
Mar 13, 2009 | Televison & Video
Security code
From user manual :
"In case you forget your passcode, follow the steps below to delete it.
1. Select the Advanced menu from the Basic/Custom menu. The Passcode
entry screen will be displayed.
2. Press the SELECT (up) button four times and then press the ENTER
button.
The "Warning Passcode!!" message will be displayed.
3. Press the SELECT (down) button four times and then press the ENTER
button.
4. Press the SELECT (right) button four times and then press the ENTER
button.
The "Delete Passcode / Are you sure?" message will be displayed.
Use the SELECT or button to select "Yes" and press the ENTER
button. Your passcode has been deleted."
Sep 08, 2008 | NEC LT20 Multimedia Projector
1974 super beetle
either the booster is bad or your proportioning valve is bad switch these out and repeat the bleeding proccess this should solve the problem
Sep 01, 2008 | Volkswagen Beetle Cars & Trucks
HP Pavilion dv6000z Notebook Logo
18 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
