Question about Watches
How to set a c9 watch. Or an instruction manual.
How much is a c9 cr2016 watch worth?
http://price.salespider.com/cpidt2-b76ab6bb1fa02d11c385a54782005b49/mens-c9-by-champion-analog-digital-watch-blackorange
Aug 06, 2015 | Watches
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
Replacing a battery on a C9 by Champion Womens watch
to change the battery in a champion watch:
(1) remove the back, (2) carefully peel loose the foam strip and set it aside (3) release the battery retaining bracket with a needle or awl and tweezers, (4) grasp the case with your thumb and forefinger so that your thumb is holding the works inside the case, (5) turn the watch over and the battery should fall out (6) put the new battery in the holder, (7) snap the retaining bracket back in place (8) replace the foam strip (9) replace the back 5b238361-61b1-4b0d-ab40-54fb346f5586.jpg
Dec 07, 2013 | Geneva Watch Group C9 by Champion Womens...
C9 champion digital alarm
Since you don\'t know how to turn it off, the alarm will give you simple instructions. Just stop pressing the buttons. Is there a symbol or an alarm or clock on any of the buttons?
May 10, 2013 | Watches
How to set my c9 champion watch date, day, time
Hold the bottom right button (lap/reset) until it beeps and comes up with "SET". The bottom left button (mode) will alternate between what you are increasing (Hour, minute, month, day, ect) and the top right (start/stop) will increase it by one (hold to make it go faster). When done, just hit the bottom right button again.
Jul 29, 2012 | Watches
How do I reset the distance ?
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please . .
Apr 20, 2010 | Sportline C9 by Champion Fitness 910 Watch
How do you turn on the heart rate monitor on a sportline heart rate watch
Apr 19, 2010 | Sportline C9 by Champion Fitness 910 Watch
What is the pace function for? and how should i set it?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SPORTLINE watch manuals.Pace is the relative progress or change of continuous speed.Rate me, please
Mar 22, 2010 | Sportline C9 by Champion Fitness 910 Watch
Setting the time
On the C9 Fast Wrap Strap digital watch, press and hold the "LAP/RST" button until the display shows "SET" then release. Use the "MODE" button to switch between second, minute, hour, etc. Use the "ST/STP" button to change. Press and release the "LAP/RST" button to exit. The Sportline might be the same or similar.
Mar 15, 2010 | Sportline C9 by Champion Fitness 910 Watch
Watches Logo
847 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
