Question about Bosch Saws
Brand new bosch 4100 jobsite table saw
Sliding extention table seems to have a lot of up and down movement when extended
  • 2,176 Answers
There are no adjustments on the movement you described. If this is a new saw as indicated I would return for warranty repair/replacement.
Posted on Feb 10, 2012
Testimonial: "That is what I thought I couldnt see any way to adjust or tighten this. I contacted bosch and they also suggested returning it. I also contacted the qualified bosch repair place and they said they havent heard of this proplem . I must have just got a bad one. I contacted Home Depot and they are going to exchange it no problem. I mean I was just setting it up and hadnt even cut a piece of wood with it yet. Thanks for fed back"
rowdy45176
  • 2176 Answers
SOURCE: Table Saw blade
Did you remove the center plate? It has to come out before you can remove the blade. Also make sure that the saw is unplugged before you go any further. If you still have questions contact me and I will do what I can. Also if you would like you can download a schematic of this tool at Makitatools.com just type in your model and look at the schematic. Good luck
Posted on Jan 03, 2009
  • 107 Answers
SOURCE: I purchased the Bosch saw blade on Ebay
If the arbors the same and you're running with in the RPM rating, it will be fine. But ALWAYS wear your safety glasses.
Posted on Mar 15, 2009
rowdy45176
  • 2176 Answers
SOURCE: Bosch 4000 table saw. The saw stopped while
If you are mechanically inclined and it sounds that way do you have a volt ohms meter?? If so start at the cord and check the continuity to the brush holders. Why did you replace the field? You might have had a stuck brush or some other problem. Make sure the brushes move freely in the tubes and also look for discoloration on the commutator of the armature. Let me know what you find and I will try and help you thru the rest of it.
Posted on Aug 25, 2009
slave2aslave
  • 302 Answers
SOURCE: I have a 10'' table saw
If it cuts straight it's fine. It's likely just some play in the bearings. I wouldn't worry about it unless it starts to cut not so straight...
Posted on Oct 06, 2009
Testimonial: "thanks, I thought I was going to need to spend money for repairs. "
  • 8404 Answers
SOURCE: Bosch table saw was working. When I went to make
did you press the reset button? check the plug and check the breaker.
Posted on Nov 03, 2009
I have a Bosch 4100 table saw. The first indication of trouble was that the rpm's seemed to be running dangerously high. Then after cutting a couple of small boards to get through the day, the rpm's t
Make sure the tool is unplugged - on the motor there is a cap held on by 2 screws. Inside you will find the speed control #2610997306 and while you are there I would recommend changing the brushes #2610997207
You can purchase these parts from ereplacementparts.com
Jan 28, 2015 | Bosch 4100 09 10" Worksite Table Saw...
Bosch table saw GTS1031 won't start.
In case of this kind of questions you can only advise someone to go back immediately where they have bought the tool for warranty or exchange or money back.
No other suggestions but few years to late to give the only right answer in this cause of question.
Aug 29, 2014 | Bosch GTS1031 10-in Portable Jobsite Table...
Riving Knife won't go down enough.
ok thank you for reporting that your problem was solved.
Feb 18, 2012 | Bosch 4100 09 10" Worksite Table Saw...
Smoking
if it is smoking when power is switch on - there is a chance that the motor winding has shorted out. OR it could just have sawdust in the motor, ( use a air compressor to blow down the saw and motor and see if this solves the problem ).
c...
Jan 02, 2011 | Bosch 4100 10" Worksite Table Saw
Electric blade brake sounds like it is seized up. Upon starting table saw (bosch 4000), motor sounds like it is binding. How can I disengage the brake??
There is no electric brake on the Bosch 4100 table saw. If the motor sounds like it is being held back its possible the rear armature bearing has seized or the field coil is faulty. Both these problems cause the motr to not turn at full speed. The motor must be serviced.
Dec 08, 2010 | Bosch 4100 10" Worksite Table Saw
I was cutting 2" dense foam insulation board,
The problem you have is a faulty field coil, the Bosch saws unfortunatly have a bit of an issue with this. The coil can be replaced separatly so you won't have to replace the whole motor. Bosch has a 1 yr warranty on thier table saw so this is a warranty replacment provided the saw was purchased within the year. If not the coil replacment is still cheaper than buying a whole new saw, but should really be done by a service center because of the level of difficulty of the repair.
Nov 10, 2010 | Bosch 4100 10" Worksite Table Saw
For about six months my bosch table saw has imtermitent motor problems sometimes it works other times it doesn't now the motor is smoking how do i get a new motor
Parts diagram is here.
Looks like you can't just buy a new motor.
Service center locator is here. Click the Portable Electric & Battery Power Tools button. Put in your zip code and you can call around to see who can fix you up the quickest.
It looks like warranty on this saw is one year. Depending on how old your saw is, it may even be covered under warranty.
Jun 09, 2010 | Bosch 4100 09 10" Worksite Table Saw...
Saw slowed down. Shut off saw and restarted. runs backward.
Sonmethings shorted out inside motor / strip and see if any debris is in there.
It has somehow repolarised from the negative side to pos side!!
Jan 20, 2010 | Bosch 4100 10" Worksite Table Saw
Saws Logo
163 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
River bottom
Are you a Bosch Saw Expert? Answer questions, earn points and help others
